I finally get to make the nVidia GPU working, with the Nvidia-commander (don't know the exact name)
but the audio is not working as of now.
I tried to use multishit but still no luck
by checking the Optional 3 Port (5.1) Audio, 100/200/300 Series Audio, or 200 / Z370 Series / X299 Audio Device ID Patch
I also tried this option series but still no luck
<IMGUR id="bGqQMaY"><a href=https://i.imgur.com/bGqQMaY.png' alt='IMGUR>'>
this is my sendme file
https://gofile.io/?c=vYzbTm
also the audio device is not detected :(
<IMGUR id="OpmbNtm"><a href=https://i.imgur.com/OpmbNtm.png' alt='IMGUR>'>
heres my updated file send_me file https://file.io/9oqkVb
CPU: Intel® Core i5-9400F
MOBO: ECS > H310CH5-M2
GPU: Nvidia GTX 750ti
just solve a video problem for one real vanilla start
I have a question, why is it that my audio devices is empty? :(
Somehow the AppleALC got working but it reads the HDMI which is I didn't use its port, I have a pink, green, blue audio
never use this tool
check here
https://Olarila.com/forum/viewtopic.php?f=28&t=9788
have some options for ur audio codec
Still not working, Already injected the layout-id of 5
<IMGUR id="Qhwjc3R"><a href=https://i.imgur.com/Qhwjc3R.png' alt='IMGUR>'>
<IMGUR id="KlgUWAF"><a href=https://i.imgur.com/KlgUWAF.png' alt='IMGUR>'>
also in https://Olarila.com/forum/viewtopic.php?f=28&t=9788
it says that
HDAS to HDEF
48444153
48444546
but it is already on the clover config
<IMGUR id="GkNfuiY"><a href=https://i.imgur.com/GkNfuiY.png' alt='IMGUR>'>
<IMGUR id="Hxbqd9w"><a href=https://i.imgur.com/Hxbqd9w.png' alt='IMGUR>'>
I use layout 5 because I have blue, green, pink audio input.
I still don't know what to do :(
<IMGUR id="Oknf5MF"><a href=https://i.imgur.com/Oknf5MF.png' alt='IMGUR>'>
I have a good news, its working now, I use layout number 5 and I have to download the new AppleALC.kext, thanks for all your help MaLd0n
