ALC 288 no sound wake from sleep
hi all, on my Dell XPS 9343 Catalina work well except i have no sounds when I wake up from sleep. I tested with alchda and Lilu or woodoo .I change on clover layout 3 or 13 or 23 same result no sound on speaker ,headphones and microphone work ok, when wake .I have to restart for sound work. I see audio solution but on folder 288 tree layout no change and other file (plist and platform i have to use them as)
dell xps13 9360
core i7
Intel HD620
-ram 8 gb ddr3
-hard disk da 256 gb SDD
[ref]vrondena[/ref], try with codeccommander, if need edit this kext
codec commander not include all 288 , Archivio.zipI entered the entry alc288 to replace 283 but it doesn't work, I don't understand if correctly. you can kindly do it .thanks
dell xps13 9360
core i7
Intel HD620
-ram 8 gb ddr3
[ref]vrondena[/ref], try with ssdt method by Rehabman
I came back with high sierra the sound after waking up works using HDA Patcher. files created in HS but also recreated in Catalina do not work which uses ALC in clover for sound. you have suggestions, thanks
dell xps13 9360
core i7
Intel HD620
-ram 8 gb ddr3
