Problem when trying to install High Sierra.
[ref]zKamp[/ref], use nullcpupm kext
[ref]zKamp[/ref], PATCHED HPET DEVICE INTO DSDT
[ref]zKamp[/ref], dsdt
Now I have another problem. I can't mount the EFI partition, I can't mount my SSD. I tried with Mounter Pro, EFI mounter and in the terminal I get this message
Volume on disk0s1 failed to mount
If the volume is damaged, try the "readOnly" option
If the volume is an APFS Volume, try the "diskutil apfs unlockVolume" verb
[ref]zKamp[/ref], :shock:
[ref]zKamp[/ref], install again, use guid and hfs or apfs
apfs
It's just that I had to choose, Mac OS Extended (Journaled) because I didn't get apfs or hfs.
Only these options appeared to me:
Mac OS Extended (Journaled, Encrypted)
Mac OS Extended (Case-sensitive, Journaled)
Mac OS Extended (Case-sensitive, Journaled, encrypted)
ExFAT
MS-DOS (FAT)
[ref]zKamp[/ref], Mac OS Extended (Journaled)
I don't understand. I guess I managed to set up EFI, but now only these folders that were hidden show up, or is that okay?
.fseventsd
.Spotlight-V100
.Trashes
[ref]zKamp[/ref], just ignore
But only those three appear to me. Shouldn't I get the EFI folder? (I really don't know, I'm new and I want to start without the usb)
Sorry for the ignorance.
[ref]zKamp[/ref], just ignore folders if u load via windows ;)
But I mounted it on Mac, not Windows. Could I pass the EFI folder from the USB to there?
I finished the installation, you might say. Then I give as solved the problems said in this thread. Thanks for helping!
