first of all i want to thank you for your work and your time on helping me and many others
and without your help i wont be able to make a new topic using macOs on my laptop
From installing hackintosh untill using it i faced many problems and the solution was here by your help and also many many thank for you.
I have Ideapad L340-15IWL , i7-8565U , UHD620
- My main problem now is the battery , it took almost 6 hrs on working in windows but it is only 2:30 hrs in hackintosh
even i do not touch the trackpad it drains quickly ,and i really need it cause i am student and need the laptop for programming and i need macOS,
i think maybe i made a wrong confgs or any mistake but i do not know i used many SMBIOS to see the change but the same result,
so please could you check my files if there are any problems that make the battery life like this ?!!
- Another annoying problem when i boot , if i used -v flag the laptop boots normally but it took a minute or more to boot from clover to desktop(that makes me feel that my laptop is slow) and give me many many lines of [ELAN625 invalid report 255],
and if i remove -v flag the laptop keeps restarting when apple logo appears and i have to use -v to boot up, really annoying.
- Another small problem is that in display settings the AirPlay is always off after you fixed my UHD 620 ,and the icon does not appear in the bar, although it was working and appearing in the bar when i installed macOS using your EFI native folder but then does not work.
- Another tiny problem is the HDMI sound does not work.
So please if you have a time to look up for my problems and my files to help me please help
and again and again thank you very much
https://gofile.io/?c=otopcJ
[ref]m0ustafamahm0ud[/ref], check useful links, have many solutions
