High Sierra Freeze or Shutdown Random pls Help
Hey Guys,
I wanted to update my Hackintosh and used your guide and image to install HighSierra on a new SSD.
The Installation was easy but I have some random freezes, where my Inputs stop working and if I'm listening to Music the audio starts looping strangely.
I tried some fixes that I find in different forums but nothing helped. Now my Hackintosh restarts randomly.
I somehow believe it's connected to heavy load or the USB Limit that comes with High Sierra. But your Image should have considered that as I could see in the Clover Config.
My Specs are:
MoBo: Asus x99 Deluxe
CPU: Intel i7 5960x
Graphics: Nvidia GTX 980
24 GB RAM
Strangely I got another SSD where I have 10.10.3 running just fine. There I used Chameleon. But I would like to have the Clover SetUp working.
It would be great if someone can help me.
[ref]DesignZoo[/ref], post one dump, ill check
--Run_Me
RunMe.app
Hey man thank you. Hier is my file.
https://www.file-upload.net/download-13838151/SendmeAlberts-iMac.fritz.box.zip.html
tell me what you finde. I some how think its conected to my ram. it was more stable when i run the HighSierra system with 8 or 16 GB of Ram. If put 24 or 32 inside it starts freezing. I just added the rum specs in clover and lets see if this allready helps. But if you can finde some other thing that makes the trouble let me know.
I remeber haveing problems with the CPU-Friend think. I think i Could not finde every entry in my DSDT:( Maybe thats an issue too.
Strangly with the Chamelon boot i have no such problems, even with 32 GB ram
