HELP 1060 not recognized High sierra
[ref]ELI4S[/ref], select NvidiaWeb in ur config.plist
[ref]ELI4S[/ref], sound like ur nvram don't work, for nvdia web driver need a nvarm work or emulate
[ref]ELI4S[/ref], u can try with EmuVariableUefi.efi
[ref]ELI4S[/ref], if don't work, u need a full dsdt patched
[ref]ELI4S[/ref], Extract tables with F4 key in Clover boot screen, files generated in Clover/Acpi/origin, post here
[ref]ELI4S[/ref], DSDT.aml.zip
use Olarila folder serie 100/200/300
MaLd0n, I replace my Folder by Olarila folder serie 100/200/300
and I copied dsdt.aml to EFI/EFI/CLOVER/ACPI/patched but same problem
ty
[ref]ELI4S[/ref], this dsdt fix it, burn image again, the problem is not normal
[ref]ELI4S[/ref], no, same file
MaLd0nt,hank you all works !! :D
To optimize my adobe pc, do I need to install anything else?
I already installed web driver, cuda and shikigva=256.
than you.
[ref]ELI4S[/ref], ;)
