Broadcom BCM94352Z bluetooth not detected in macOS Catalina
Hello everyone,
I installed the Broadcom BCM94352Z wi-fi / bluetooth combo card on my laptop and it worked great on macOS Mojave 10.14.4, but now that I installed macOS Catalina 10.15.1, wi-fi works right OOTB, but bluetooth is not even detected. I followed the same ReHabMan tutoriaI I did for Mojave, but it doesn't work on Catalina. Any ideas on how to solve this issue? Thanks a lot for your time and help.
Laptop Lenovo Ideapad 300-15isk 80RS
Intel core i5 6200U @ 2,40 GHZ
16 GB RAM
Intel HD 520 Graphics
480 GB SSD
1 TB SATA HD
Thanks, MaLdOn! But I must be doing something wrong. I followed the tutorial, which is not very easy to follow, and I thought it was all right because now my system recognises that there is bluetooth, but when I tested it, I can't actually connect to any bluetooth devices.
UPDATE - Dec-09-2019:
The issue was simpler than I thought. Bluetooth actually sees my Android phone, and only stays connected if there's data being exchanged between my Hackintosh and the phone itself, otherwise it shows as 'NOT CONNECTED'. Live and learn... Also, I had forgotten to activate 'Bluetooth sharing'. Now everything works as expected.
Thanks again,MaLdOn!
9 minutes ago, Javier Pérez Fernández said:
Can you please just tell where to put those archives? I have a Broadcom BCM94350ZAE and although my hackintosh detects it, it doesn’t find any network or at least find them!
https://github.com/acidanthera/AirportBrcmFixup
no
  • Thanks 1
