Catalina doesn't go to sleep, also battery indicator problems.
Laptop:
Clevo P65/P67SE
i7-4720HQ
GTX 970
Intel HD Graphics 4600
[ref]iPB[/ref], check what device block sleep
log show --style syslog | fgrep "Wake reason"
~ % log show --style syslog | fgrep "Wake reason"
2019-11-28 22:40:33.175031+0100 localhost kernel[0]: (AppleACPIPlatform) AppleACPIPlatformPower Wake reason: SLPB LID0
2019-11-28 22:40:33.175032+0100 localhost kernel[0]: (AppleACPIPlatform) AppleACPIPlatformPower Wake reason: SLPB LID0
2019-11-30 10:05:21.047342+0100 localhost powerd[72]: [powerd:sleepWake] Wake reason: "" identity: ""
2019-11-30 10:55:22.157127+0100 localhost powerd[72]: [powerd:sleepWake] Wake reason: "" identity: ""
2019-11-30 10:57:25.116828+0100 localhost kernel[0]: (AppleACPIPlatform) AppleACPIPlatformPower Wake reason: GLAN EHC1 EHC2
2019-11-30 10:57:25.116830+0100 localhost kernel[0]: (AppleACPIPlatform) AppleACPIPlatformPower Wake reason: GLAN EHC1 EHC2
2019-11-30 11:15:57.585584+0100 localhost powerd[72]: [powerd:sleepWake] Wake reason: "" identity: ""
2019-11-30 11:18:00.327819+0100 localhost kernel[0]: (AppleACPIPlatform) AppleACPIPlatformPower Wake reason: GLAN EHC1 EHC2
2019-11-30 11:18:00.327821+0100 localhost kernel[0]: (AppleACPIPlatform) AppleACPIPlatformPower Wake reason: GLAN EHC1 EHC2
2019-11-30 14:41:02.394852+0100 localhost powerd[72]: [powerd:sleepWake] Wake reason: "" identity: ""
2019-11-30 16:27:27.032626+0100 localhost powerd[72]: [powerd:sleepWake] Wake reason: "" identity: ""
2019-11-30 16:29:40.728519+0100 localhost kernel[0]: (AppleACPIPlatform) AppleACPIPlatformPower Wake reason: GLAN EH01 EH02
2019-11-30 16:29:40.728521+0100 localhost kernel[0]: (AppleACPIPlatform) AppleACPIPlatformPower Wake reason: GLAN EH01 EH02
2019-11-30 18:20:16.368710+0100 localhost powerd[72]: [powerd:sleepWake] Wake reason: "" identity: ""
2019-12-01 10:04:23.035275+0100 localhost powerd[72]: [powerd:sleepWake] Wake reason: "" identity: ""
2019-12-01 10:08:41.867625+0100 localhost kernel[0]: (AppleACPIPlatform) AppleACPIPlatformPower Wake reason: GLAN EHC1 EHC2
2019-12-01 10:08:41.867630+0100 localhost kernel[0]: (AppleACPIPlatform) AppleACPIPlatformPower Wake reason: GLAN EHC1 EHC2
2019-12-01 11:17:34.028345+0100 localhost powerd[72]: [powerd:sleepWake] Wake reason: "" identity: ""
2019-12-01 11:21:56.173101+0100 localhost kernel[0]: (AppleACPIPlatform) AppleACPIPlatformPower Wake reason: RTC (Alarm)
2019-12-01 11:21:56.173107+0100 localhost kernel[0]: (AppleACPIPlatform) AppleACPIPlatformPower Wake reason: RTC (Alarm)
2019-12-01 12:01:23.033898+0100 localhost kernel[0]: (AppleACPIPlatform) AppleACPIPlatformPower Wake reason: SLPB LID0
2019-12-01 12:01:23.033900+0100 localhost kernel[0]: (AppleACPIPlatform) AppleACPIPlatformPower Wake reason: SLPB LID0
2019-12-01 12:39:08.652254+0100 localhost powerd[72]: [powerd:sleepWake] Wake reason: "" identity: ""
2019-12-01 12:40:57.289800+0100 localhost kernel[0]: (AppleACPIPlatform) AppleACPIPlatformPower Wake reason: PWRB (User)
2019-12-01 12:40:57.289802+0100 localhost kernel[0]: (AppleACPIPlatform) AppleACPIPlatformPower Wake reason: PWRB (User)
2019-12-01 13:01:20.324459+0100 localhost powerd[72]: [powerd:sleepWake] Wake reason: "" identity: ""
2019-12-01 13:03:13.827810+0100 localhost kernel[0]: (AppleACPIPlatform) AppleACPIPlatformPower Wake reason: RTC (Alarm)
2019-12-01 13:03:13.827812+0100 localhost kernel[0]: (AppleACPIPlatform) AppleACPIPlatformPower Wake reason: RTC (Alarm)
2019-12-01 19:00:17.130120+0100 localhost powerd[72]: [powerd:sleepWake] Wake reason: "" identity: ""
2019-12-01 19:00:37.098665+0100 localhost kernel[0]: (AppleACPIPlatform) AppleACPIPlatformPower Wake reason: GLAN EHC1 EHC2
2019-12-01 19:00:37.098667+0100 localhost kernel[0]: (AppleACPIPlatform) AppleACPIPlatformPower Wake reason: GLAN EHC1 EHC2
2019-12-01 19:00:55.806911+0100 localhost kernel[0]: (AppleACPIPlatform) AppleACPIPlatformPower Wake reason: GLAN EHC1 EHC2
2019-12-01 19:00:55.806913+0100 localhost kernel[0]: (AppleACPIPlatform) AppleACPIPlatformPower Wake reason: GLAN EHC1 EHC2
2019-12-02 09:25:06.480334+0100 localhost powerd[72]: [powerd:sleepWake] Wake reason: "" identity: ""
2019-12-02 09:25:26.090752+0100 localhost kernel[0]: (AppleACPIPlatform) AppleACPIPlatformPower Wake reason: GLAN EHC1 EHC2
2019-12-02 09:25:26.090754+0100 localhost kernel[0]: (AppleACPIPlatform) AppleACPIPlatformPower Wake reason: GLAN EHC1 EHC2
[ref]iPB[/ref], remove _prw from devices
into_all method label _PRW  remove_entry;
into_all all code_regex Name.*_PRW.*\n.*\n.*\n.*\n.*\}\) remove_matched;
[ref]iPB[/ref], need a rtc patch
Device (RTC)
                   Name (_HID, EisaId ("PNP0B00") /* AT Real-Time Clock */)  // _HID: Hardware ID
                   Name (_CRS, ResourceTemplate ()  // _CRS: Current Resource Settings
                       IO (Decode16,
                           0x0070,             // Range Minimum
                           0x0070,             // Range Maximum
                           0x00,               // Alignment
                           0x02,               // Length
into Low Pin Count device
[ref]iPB[/ref], u need remove native rtc and add new into lpc device
[ref]iPB[/ref],
into_all device label RTC remove_entry;
into device name_adr 0x001F0000 insert
begin
Device (RTC)\n
               {\n
                   Name (_HID, EisaId ("PNP0B00"))  // _HID: Hardware ID\n
                   Name (_CRS, ResourceTemplate ()  // _CRS: Current Resource Settings\n
                   {\n
                       IO (Decode16,\n
                           0x0070,             // Range Minimum\n
                           0x0070,             // Range Maximum\n
                           0x00,               // Alignment\n
                           0x02,               // Length\n
                           )\n
                   })\n
               }\n
end
Unresolved, i applied the patch, goes to sleep, to activate it I have to press button start, but then it restarts.
