Hello everyone,
I have this problem and I've researched the issue for about 3-4 hours and nothing has worked, so I thought I'd finally open a thread. I've successfully installed Mojave onto my SSD partition and it boots up perfectly via the USB, but not so much through Clover on SSD. The boot gets stuck at End RandomSeed:
Start and End InitBootStruct
Start and End LoadRAMDisk
Start FinalizeBootStruct
Start and End RandomSeed
I've already:
1. moved EFI from USB to SSD
2. used the bcfg boot dump method
3. tied every single Memory .efi file.
If anyone knows a possible solution, I'd really appreciate this. I need Xcode for a class and just don't have thousands of dollars for a damn Mac.
Thank you in advance!
[ref]paularnauld[/ref], use same efi folder from ur usb stick
I already did but it didn't work. :( Copied EFI from my USB stick into the EFI partition on my SSD.
Added in 18 minutes 36 seconds:
I just tried replacing my EFI folder with the one provided by Olarila (in the SSD) and the funny thing is that the macOS partition didn't show up at all.
