Its been about a week or so since I’ve been stuck with a series of problems that i was able to solve alone , I got the sound and brightness to work I haven’t tested the hdmi yet right now the problem is with the battery and touchpad
I can’t click anything with the touchpad but can move around using the mouse , the battery meter says my laptop is 100% charged and when i plug in the charger it doesn’t charge , also 2 USB ports arent working correctly when i connect something into them it says whatever i connect isnt getting enough power , can anyone assist me with a bit of help ?
My specs are
DELL INSPIRON 3521
Ivy Bridge i5 3337U @1.80ghz
8gb ddr3
Intel Hd Graphics 4000
Audio realtek alc282
[ref]bvrbng777[/ref],
--Run_Me
RunMe.app
[ref]bvrbng777[/ref], first, don't use folder from Olarila image, is just for install, this config kill device ec etc, is just for install
MaLD0n I started from scratch followed all the instructions but I seem to keep running into the same problems
Brightness is not working
Trackpad is not clicking (can move mouse but no gestures no click via button or pad )
My usbs are not working correctly , not enough power ? but usb 2.0 dongles work ?
Battery icon when pluggled is always 100% but isnt charging at all
webcam isnt working either !!! but not super important
I ran the Runme.app after making the changes you pointed out and attached the file so you can have a look !!!
at this point i've been trying almost for a whole week straight and my results have been slow , im not having much luck here ...plz help me this is giving me a huge headache .
file.zip
[ref]bvrbng777[/ref], this correct folder is for start a good config, remove edited dsdt and use only Olarila folder, i need send_me with this folder only
Hey there MaLd0n !! I'm back once again .
I re-installed the OS again (clean install ) used the correct clover folder and ran the RunMe.app to generate the File ( I have included the file )
I really hope you can help . :help
File.zip
[ref]bvrbng777[/ref], stay strange
Thanks a lot , I placed the DSDT File in the patched folder and it booted up working W/ brightness & sound :D perfect
the only 2 things that aren't working is the clicking on the trackpad and the battery meter is stuck, 2 usbs arent getting enough power & cam seems not working ? Sorry for asking again but do you know how i can solve this sir ?
[ref]bvrbng777[/ref], check my signature, useful links
