nikhilrathore_1999 Posted December 8, 2019 Author Posted December 8, 2019 Last issue my all fn keys works except brightness and audio might have problem when i switch from windows to catalina then my laptop speaker won't work headphone jack works can u suggest a fix?? Added in 28 minutes 24 seconds: i find my ec method using asussmc it shows Q0F, QD3 full increase and QOE,QD4 for down can u suggest now for brightness [ref]nikhilrathore_1999[/ref], No idea. I don't have Asus laptop to test. ??
onemanosx Posted December 8, 2019 Posted December 8, 2019 i find my ec method using asussmc it shows Q0F, QD3 full increase and QOE,QD4 for down can u suggest now for brightness AsusSMC might be using a different method I am not sure of. However, based on the guide here https://Olarila.com/forum/viewtopic.php?f=28&t=8396 Using this patch is possible by simply making the mentioned changes, 1. Replace _Q1D & _Q1C with your EC method. 2. Replace PS2M with your keyboard device name 3. Check if your DSDT uses LPC or LPCB and change the patch accordingly. 4. Apply patch. into method label _Q1D replace_content begin // Brightness Down\n Notify(\_SB.PCI0.LPCB.PS2M, 0x0205)\n Notify(\_SB.PCI0.LPCB.PS2M, 0x0285)\n end; into method label _Q1C replace_content begin // Brightness Up\n Notify(\_SB.PCI0.LPCB.PS2M, 0x0206)\n Notify(\_SB.PCI0.LPCB.PS2M, 0x0286)\n end; when i switch from windows to catalina then my laptop speaker won't work headphone jack works No idea. Donate Gitter Chat Acer Aspire V15 Nitro- Black Edition VN7-592G/HM170 Chipset Intel i7-6700HQ, 8GB RAM (UEFI Clover Catalina) MSI B360 Gaming Arctic Intel i5-8600 16GB RAM Asus Radeon RX580 8GB (UEFI Clover Catalina)
nikhilrathore_1999 Posted December 8, 2019 Author Posted December 8, 2019 AsusSMC might be using a different method I am not sure of. However, based on the guide here https://Olarila.com/forum/viewtopic.php?f=28&t=8396 Using this patch is possible by simply making the mentioned changes, 1. Replace _Q1D & _Q1C with your EC method. 2. Replace PS2M with your keyboard device name 3. Check if your DSDT uses LPC or LPCB and change the patch accordingly. 4. Apply patch. into method label _Q1D replace_content begin // Brightness Down\n Notify(\_SB.PCI0.LPCB.PS2M, 0x0205)\n Notify(\_SB.PCI0.LPCB.PS2M, 0x0285)\n end; into method label _Q1C replace_content begin // Brightness Up\n Notify(\_SB.PCI0.LPCB.PS2M, 0x0206)\n Notify(\_SB.PCI0.LPCB.PS2M, 0x0286)\n end; No idea. finally all works fine everything last thing I wanted to ask you about battery drainage(I removed every ssdt and extra kext in my clover) Added in 11 minutes 2 seconds: finally all works fine everything last thing I wanted to ask you about battery drainage(I removed every ssdt and extra kext in my clover) https://drive.google.com/open?id=11gO-px2e8OhOBJ7ebTk6lqAqtC1r-Go3 Added in 4 minutes 51 seconds: finally all works fine everything last thing I wanted to ask you about battery drainage(I removed every ssdt and extra kext in my clover) Added in 11 minutes 2 seconds: https://drive.google.com/open?id=11gO-px2e8OhOBJ7ebTk6lqAqtC1r-Go3 Last Issue my trackpad not as smooth as in windows can u fix?Screenshot 2019-12-08 at 6.11.51 PM.zip
nikhilrathore_1999 Posted December 9, 2019 Author Posted December 9, 2019 AsusSMC might be using a different method I am not sure of. However, based on the guide here https://Olarila.com/forum/viewtopic.php?f=28&t=8396 Using this patch is possible by simply making the mentioned changes, 1. Replace _Q1D & _Q1C with your EC method. 2. Replace PS2M with your keyboard device name 3. Check if your DSDT uses LPC or LPCB and change the patch accordingly. 4. Apply patch. into method label _Q1D replace_content begin // Brightness Down\n Notify(\_SB.PCI0.LPCB.PS2M, 0x0205)\n Notify(\_SB.PCI0.LPCB.PS2M, 0x0285)\n end; into method label _Q1C replace_content begin // Brightness Up\n Notify(\_SB.PCI0.LPCB.PS2M, 0x0206)\n Notify(\_SB.PCI0.LPCB.PS2M, 0x0286)\n end; No idea. ??
onemanosx Posted December 9, 2019 Posted December 9, 2019 Last Issue my trackpad not as smooth as in windows can u fix? Update BIOS if it's available. Or, wait for new release of kext. battery drainage You cannot compare battery life between Windows and hack. Generally, battery is bad in hackintosh. Remove VoodooTSCSync.kext if you can boot without it. Donate Gitter Chat Acer Aspire V15 Nitro- Black Edition VN7-592G/HM170 Chipset Intel i7-6700HQ, 8GB RAM (UEFI Clover Catalina) MSI B360 Gaming Arctic Intel i5-8600 16GB RAM Asus Radeon RX580 8GB (UEFI Clover Catalina)
nikhilrathore_1999 Posted December 10, 2019 Author Posted December 10, 2019 Update BIOS if it's available. Or, wait for new release of kext. You cannot compare battery life between Windows and hack. Generally, battery is bad in hackintosh. Remove VoodooTSCSync.kext if you can boot without it. A problem is occured when it goes into deep sleep then it restarted and work is gone can u suggest a fix ?? Added in 6 minutes 42 seconds: A problem is occured when it goes into deep sleep then it restarted and work is gone can u suggest a fix ?? ???
nikhilrathore_1999 Posted December 10, 2019 Author Posted December 10, 2019 Update BIOS if it's available. Or, wait for new release of kext. You cannot compare battery life between Windows and hack. Generally, battery is bad in hackintosh. Remove VoodooTSCSync.kext if you can boot without it. ??
nikhilrathore_1999 Posted December 11, 2019 Author Posted December 11, 2019 Update BIOS if it's available. Or, wait for new release of kext. You cannot compare battery life between Windows and hack. Generally, battery is bad in hackintosh. Remove VoodooTSCSync.kext if you can boot without it. Hello onemanosx are u there??
nikhilrathore_1999 Posted December 12, 2019 Author Posted December 12, 2019 Update BIOS if it's available. Or, wait for new release of kext. You cannot compare battery life between Windows and hack. Generally, battery is bad in hackintosh. Remove VoodooTSCSync.kext if you can boot without it. Hello onemanosx!!!
onemanosx Posted December 13, 2019 Posted December 13, 2019 You need to troubleshoot what is wrong with your machine. In some cases, sleep dont work. Donate Gitter Chat Acer Aspire V15 Nitro- Black Edition VN7-592G/HM170 Chipset Intel i7-6700HQ, 8GB RAM (UEFI Clover Catalina) MSI B360 Gaming Arctic Intel i5-8600 16GB RAM Asus Radeon RX580 8GB (UEFI Clover Catalina)
nikhilrathore_1999 Posted December 15, 2019 Author Posted December 15, 2019 [ref]nikhilrathore_1999[/ref], use intelgfx fake 0x12345678 Hello Mald0n, I am very happy because my laptop is fully configured to macOs catalina 10.15.2, but there is one issue left battery is drain very fast and internal microphone only works when headphone is connected without it cannot worksI use crucial bx500 240SSD which takes 24 sec to boot macOs can i get more fast boot time please help me out for above issues, Thanks Mald0n!!!
nikhilrathore_1999 Posted December 15, 2019 Author Posted December 15, 2019 (edited) You need to troubleshoot what is wrong with your machine. In some cases, sleep dont work. finally all works great fully supported in my laptop --> Solved Edited December 28, 2019 by Guest
nikhilrathore_1999 Posted December 22, 2019 Author Posted December 22, 2019 You need to troubleshoot what is wrong with your machine. In some cases, sleep dont work. Hello onemanOsx, Mirroring not working with intel hd620 also i cannot get mirroring icon in menu bar for wifi i used usb wifi with cloverCan u suggest any fix
