[ref]nikhilrathore_1999[/ref], Remove SSDTs. The errors were there since the beginning even before using my DSDT.
i've tried that i'll remove ssdt same thing happend before it was not stuck at boot but it stuck at boot the screenshot i gave you in which it is stuck at that point
[ref]nikhilrathore_1999[/ref], No idea. You need to troubleshoot. Try removing H_EC to EC rename. In clover.
Donate
Gitter Chat
MSI B360 Gaming Arctic
thanks thanks trackpad works thank you thank very much onemanosx
Added in 11 minutes 30 seconds:
one last thing can u fix battery drainage and slow boot issue
:guitar
1.You need to remove unwanted kexts and SSDTs first.
2.Optimise your clover by removing unwanted patches.
Donate
Gitter Chat
:guitar
I removed the unnecessary kext and patched u've seen I guess but still take time and also can I use native audio it think my audio codec is ALC 255
Yes.
No idea. You did not upload your new debug files.
Donate
Gitter Chat
Yes.
(bluetooth always turned on off option not working and wifi QCA9377 wifi not working, mirroring also not working, airplay not working)
native audio fix and battery drainage fix left (If I remove any of the kexts then system stuck at boot or at login this is final working sendme) not sure about audio codec just check in sendme file it says alc255
Send me Nikhils-MacBook-Pro.zip
Your BT and wifi card is not supported in any MacOS.
native audio fix
Use AppleALC + Lilu kext + correct layout ID. Make sure you have native AppleHDA kext (not modded).
Read guide in USEFUL LINKS
I think you have 3rd party kexts in SLE. Remove them.
Your config is pretty much the same as before. You did not remove SSDT or Kexts at all. Many errors in your logs causing slow boot. You need to troubleshoot yourself. Edited by Guest
Donate
Gitter Chat
I fresh install macOs catalina so i won't use any kext in SLE or LE all kext are in clover/kext/other
I've discovered one more bug brightness works but hotkeys not work and in keybord shortcuts no option of display were there for audio apple alc kextinstall int clover/kext/other what layout id should i use
1. Brightness hotkeys - Read guide in USEFUL LINKS
2. AppleALC Audio - Read guide in USEFUL LINKS. You need to find the correct id for your laptop. Test 1 id at a time after each reboot.
3. Using latest macOS will always be slow on a spindle hard drive. Change to SSD.
Donate
Gitter Chat
I'll use ssd from next month because of money issue btw which ssd u preffered(low price and effective)
Added in 41 minutes 21 seconds:
audio works i followed guide for brightness hotkeys but that doesn't work
can u provide the solution for brightneas hotkeys because useful link guid method not works for me?
What is your EC method?
Donate
Gitter Chat
ec0 to ec rename
[ref]nikhilrathore_1999[/ref], Obviously you did not read the guide. Else, you will understand the term EC method which was mentioned specifically in the guide.
That guide requires you to do the necessary for a working hotkey remapping. Each laptops are different. Good Luck.
Donate
Gitter Chat
i am so sorry to annoy you i read the guide but my console doesn't show my ec method that's why i don't know my ec method sorry to distrub please forgive me on my mistakes
Added in 14 minutes 44 seconds:
please atleast reply because i have more problem regarding audio
I have no idea if you had applied RH's debug patch and used debug kext in order to achieve the ec method in console.
However, assuming you had done correctly and no EC method were found, then you might have more luck with this solution.
https://github.com/hieplpvip/AsusSMC
Donate
Gitter Chat
[ref]nikhilrathore_1999[/ref], No idea. I don't have Asus laptop to test.
Donate
Gitter Chat
Last issue my all fn keys works except brightness and audio might have problem when i switch from windows to catalina then my laptop speaker won't work headphone jack works can u suggest a fix??
Added in 28 minutes 24 seconds:
i find my ec method using asussmc
it shows Q0F, QD3 full increase and QOE,QD4 for down can u suggest now for brightness
