thanks brights works but now system were too laggy and touchpad won't works, i'll resend the zip file in a minute
Added in 12 minutes 41 seconds:
system won't respond stuck when apple logo finish then system stuck at the time of login
I wouldnt know the cause if it boots the first time but stuck upon your second reboot. Not enough information to troubleshoot.
Donate
Gitter Chat
MSI B360 Gaming Arctic
on first boot it run too laggy and applications won't open so i hard reset
Added in 21 minutes 37 seconds:
thank you I paste your config.plist and my laptop works fine with brightness indicator but no automatic adjustment were in preference pane and trackpad won't works thanks sorry for the above post
Added in 1 minute 46 seconds:
my trackpad and battery indicator fix please thank you onemanosx
Send me Nikhils-MBP.zip
Your debug files indicates that you are not using my clover folder except for the config.plist.
Donate
Gitter Chat
i used you folder but my system stuck when login screen arrives and trackpad not works as a mouse like before and system sucks ??
It will require a few more config changes before things can work. Be patient. You need to remove all of your nonsense SSDT and DSDT and only use my DSDT. You also need to remove unused kexts in clover.
For your system not to suck, you need to know what is exactly causing it and rectify it.
Donate
Gitter Chat
i thing by using ur folder it is graphic problem that i've seen can i use fakeid 12345678 for intel hd620 because it stops when i enter password on login screen and loading then stop please guide me i foolow ur steps
graphic problem
Then you can solve this by injecting working device properties into config.plist.
I had just advised you in my previous respond.
Donate
Gitter Chat
what can i do to get into system because it stop responding after finish to apple logo
You are expected to troubleshoot on your own. You can likely boot using your USB stick.
Donate
Gitter Chat
i finally get the solution if i remove those ssdt which was generated by runme app then system stuck but if i use your dsdt woth those ssdt and config. Plist then my system works fine but my trackpad only works as a mouse if i use i2chid with i2c kext but didn't got the gestures like 2 fingure etc
Only fix is left is trackpad
Can i send new debug file to u?? Btw thankyou very much
Added in 34 minutes 1 second:
:o this is my new debug file in which everything works except trackpad and slow boot (takes 1min30 seconds to boot) please fix thank you!!
[ref]nikhilrathore_1999[/ref], You only need to boot with my DSDT. SSDT are not required. You are also expected to remove VoodooI2CHID kext. Thereafter, I need a new sendme once reboot.
Donate
Gitter Chat
if i remove ssdts then system stucks and but i use ur dsdt and config.plist and remove extra kext if i remove anything from it then system stucks i've tried everything
You need to be more descriptive. What SSDT did you remove? Where does it stuck? What is the verbose message?
What kexts did you remove? You are only required to remove VoodooI2CHID kext.
This is what you should do:
1. Use my DSDT with config.plist
2. Remove VoodooI2CHID kext
3. Reboot.
4. Extract sendme.
Donate
Gitter Chat
3. Reboot.
4. Extract sendme.
I attached debug file(fix required battery drainage, trackpad)
Send me Nikhils-MacBook-Pro.zip
kernel: considerRebuildOfPrelinkedKernel com.alexandred.VoodooI2CServices triggered rebuild
1. Rebuild permissions and kextcache required.
If you had installed kexts in L/E or S/L/E, this is the time to remove them.
2. Replace DSDT and config.plist. https://drive.google.com/file/d/1SxZFRCtSan5QDbuZI6rfSswC4l71-m-j/view?usp=sharing
3. Reboot.
4. Extract new sendme
Donate
Gitter Chat
3. Reboot.
how to run this code you've mentioned
Added in 24 minutes 14 seconds:
3. Reboot.
i rebuild kexkcache in terminal via sudo kextcache -i / and reboot then got acpi table errors
[ref]nikhilrathore_1999[/ref], Remove SSDTs. The errors were there since the beginning even before using my DSDT.
Donate
Gitter Chat
