[ref]nikhilrathore_1999[/ref], no idea
u have a trim enable?
[ref]nikhilrathore_1999[/ref], u need a video patch
https://Olarila.com/forum/viewtopic.php?f=28&t=10814
thanks Mald0n with your guidence i succesfully installed mojave10.14.6 with every thing works. THANKS THANKS MALD0N!!
Added in 2 minutes 21 seconds:
yes but still got 1min or above to start
Btw can i get native support on my touchpad
Its i2c-hid with FTE support
Use VoodooI2C and VoodooI2CFTE kexts. You will need to edit your DSDT.
Donate
Gitter Chat
MSI B360 Gaming Arctic
I used voodoops2 should i remove then i copied voodoi2c and vodoofte my trackpad only detect as a mouse and tracpad prefernce is empty shows wait for a bluetooth trackpad to discover
Added in :
[ref]nikhilrathore_1999[/ref], you need voodoops2 for keyboard. trackpad preference will show with a working battery status
Donate
Gitter Chat
battery status workinf fine with smcs,artbattery.kext everythings works but trackpad problem can't resolve
Can you patch the dsdt for my trackpad I2C FTE
Added in 2 minutes 38 seconds:
I attached my dsdt please help to patch it for trackpad FTE thanks
[ref]nikhilrathore_1999[/ref], upload full debug files or use the runme app.
Donate
Gitter Chat
IOREG dump failed. Retrying going on many times and didn't complete ??
Ensure you have IOReg v2.1 app in applications folder and RunMe is given the permissions.
https://imgur.com/kO9wVx5
Donate
Gitter Chat
I've done it now it behaves similiar to previous same
Added in 1 minute 54 seconds:
Added in 45 seconds:
Run Me app wouldn;t work properly so i attached my IORegisrty file to you
Nikhil’s MacBook Pro.zip
[ref]nikhilrathore_1999[/ref], IOreg copy alone is not helpful in troubleshooting
Donate
Gitter Chat
please fix trackpad with all multigesture support its FTE 1001 and also backlight kext for macOs catalina 10.15. Thanks!!
Please upload ACPI tables from Origin folder.
Donate
Gitter Chat
Origin folder is empty
Press F4 at clover boot menu. Wait for a moment, Then boot normally.
Donate
Gitter Chat
Replace (not merge) clover folder. Repair kextcache and permissions. Reboot. Extract new sendme.
https://drive.google.com/file/d/18b4Y346LrMfyWNAIWdQn7MsFewLzPs90/view?usp=sharing
Donate
Gitter Chat
thanks brights works but now system were too laggy and touchpad won't works, i'll resend the zip file in a minute
Added in 12 minutes 41 seconds:
system won't respond stuck when apple logo finish then system stuck at the time of login
Added in 3 minutes :
please help i had a back up of previos efi in my pendrive i can boot the system vai pendrive but won't with your clover folder correctly
