[ref]nikhilrathore_1999[/ref], use intelgfx fake 0x12345678
[ref]nikhilrathore_1999[/ref], use guid
it now also stuck at installing i install alongside windows 10 with mbr partition is it possible?
can i install macOs cataline for intel&AMD in my laptop my laptop specs
CPU: i5-7200u
Motherboard: Asus 7th Gen
GPU: intel hd 620, Nvidia 940mx
touchpad: 12IC HID
if it is possible then after installation my asusn touchpad and wifi works correctly or not
[ref]nikhilrathore_1999[/ref], yes, work
i2c device
[ref]nikhilrathore_1999[/ref], don't work native, u need extra kext and dsdt patch
I installed macOS Catalina but I can't get any graphics acceleration also my keypad and trackpad wifi not working
Asus i5-7200u
8gb ram
12CHID trackpad
help please give me EFI folder for my specs I tried several efu but any of it won't works
[ref]nikhilrathore_1999[/ref], u need use Olarila folder and start a fine tune
where can i get this folder
in catalina anythings won't works but i install mojave in which graphics, keyboard,sound works but
Brightness controller, wifi(qualcomm anthroes QCA9377), touchpad asus smart gesture (12CHID) - tried rehbman 12c kext but won't work, battery indicator won't work correctly it only shows low battery status help pleas MaLd0n
[ref]nikhilrathore_1999[/ref], check my signature, useful links
