I've downloaded the AMD image for the Catalina, but the version there is 10.15 which doesn't include support for 5700 XT. Although I've successfully installed the hackintosh I'm having a hard time upgrading it to 10.15.1, When the update got downloaded I got a new entry in clover boot loader which stated something like "Boot macOS from MacOS - data" I tried to boot from it, but it stopped at the +++++++ signs. And after I tried to boot into entry "boot macOS from MacOS (name of my partition) it went trough the boot process but without actually updating the system to 10.15.1 . What should l do? Thanks!
[ref]sofyanlabs[/ref], try it
			<dict>
			<key>Comment</key>
			<string>Black Screen Patch (c)Pike R. Alpha</string>
			<key>Disabled</key>
			<false/>
			<key>Find</key>
			<data>
			Ym9hcmQtaWQ=
			</data>
			<key>InfoPlistPatch</key>
			<false/>
			<key>Name</key>
			<string>com.apple.driver.AppleGraphicsDevicePolicy</string>
			<key>Replace</key>
			<data>
			Ym9hcmQtaXg=
			</data>
		</dict>
Added in 18 seconds:
[ref]kantagara[/ref], i'll check it
[ref]sofyanlabs[/ref], config.plist
[ref]MaLd0n[/ref], this gives me kernel panic, but I've seen now that 10.15.1 isn't even available for AMD clover, so we just have to wait for it :D
