Affoghiamoci Posted October 26, 2019 Posted October 26, 2019 Hi, I have a couple of problems with installing Catalina like Hackintosh and I hope you can help me. Starting from the fact that I used the EFI folder you recommended for my chipset, but I am forced to start with config2 to start it all correctly. I also used the installation file you recommended. - My keyboard is badly recognized for some reason, the option and command keys are reversed. Also, sometimes when I make a wrong keyboard combination it is shown to me as a bright glow. - I have no way to root the HDD root where I installed the system, this includes the impossibility to modify the EFI folder (I have to start via pendrive) - The audio is not working) - In system report the monitor is marked as a 5K when it is a 4K - At startup there are several black flashes before you can see the UI. I also posted in 3D for aptch DSDT, hoping to solve some of these problems. I appreciate your help, I intend to donate as soon as I have solved these problems.
Administrators MaLd0n Posted November 4, 2019 Administrators Posted November 4, 2019 [ref]Affoghiamoci[/ref], https://Olarila.com/forum/viewtopic.php?f=50&t=8685 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
