Doesn't look like there are any other T480s users here.. got zero search results for 'T480s'.
I have been hunting around but a lot of the guides are for the T480, which has a different trackpad, and most have the i5 CPU and a lot of the guides are for Mojave. I am trying to install Catalina.
Any help would be greatly appreciated :)
Send me Lenovos-MacBook-Pro.zip
[ref]lenovo_user[/ref], replace full efi, reboot, check if work
EFI.zip
if work, extract new send_me with new files
[ref]lenovo_user[/ref], u replace full efi folder? i see all old files there
delete send_me files in ur desktop and run app again
[ref]lenovo_user[/ref], audio is alc257 check solution here
https://Olarila.com/forum/viewtopic.php?f=28&t=9788
about ur trackpad, check bios/uefi setup if have option "Advanced"
Great thx, got audio working and the trackpad has no advanced option, but it works well.
Do you have any idea what I might do for thunderbolt and sd card reader? Others seem to have got them working, but I have no thunderbolt or sd reader in profiler.
[ref]lenovo_user[/ref], thunderbolt is working, don't work hotplug u need connect device before boot
try it
SSDT-TB3HP.aml.zip
