[Guide] Native USB Fix for Notebooks - No Injector/Kext Required
On 2/1/2022 at 6:20 PM, MaLd0n said:
search for HUB
And then after found the HUB(N)??
I want to use the HP15 and HP24 which are connected to BT and Cam. How do i make ssdt like you did without any kexts injected for usb mapping?
in this case is direct on dsdt
15 minutes ago, tasco11 said:
Can you patch this? It's for HM75. Only the EHC or EH device only.
4 hours ago, tasco11 said:
Thank you, but does _PLD really needed?
no
u can remove
