[Guide] Native USB Fix for Notebooks - No Injector/Kext Required
41 minutes ago, Zyon said:
Same issue, black screen and I need to reset ...
https://1fichier.com/?7hw94i9ywxhi99qd28ip
run these commands and reboot
pack.zip
21 minutes ago, Zyon said:
Done :)
test sleep
the config looks very good, ioreg and logs is perfect, if don't work, idk
Many thanks :)
is better, at start, and some device working now, thanks again.
Just for sound card I put voodoo kext ?
use alcid=1 in nvram tab, bootarg
Hi,
Sorry it's me again ..
Just to know if/how I can upgrade USB speed ?
I can't have more 12mbps on usb ... I have reinstall all my music app and it's unplayable ... shuttering ...
Bus USB 3.1 :
  Gestionnaire du contrôleur de l’hôte : AppleUSBXHCIPCI
  Identifiant du périphérique PCI : 0x149c
  Identifiant de révision du PCI : 0x0000
  Identifiant du fournisseur du PCI : 0x1022
GE200 :
  Identifiant du produit : 0x5703
  Identifiant du fournisseur : 0x0483  (STMicroelectronics)
  Version : 0.c8
  Numéro de série : 00000000001A
  Vitesse : Jusqu’à 12 Mb/s
  Fabricant : MOOER
  Identifiant de l’emplacement : 0x60300000 / 1
  Courant disponible (mA) : 500
  Courant requis (mA) : 500
  Exploitation supplémentaire actuelle (mA) : 0
Thank for your help
EDIT : Sorry, just bios settings :) all is good now
Edited by Zyon
this method is Amazing ?
I'm Edited my DSDT and worked for Me
Special Thanks to MaLd0n and Piker-Alpha
Laptop : Acer Aspire E5-575g-73wp, i7-6500U, GTX 940mx/HD 520
Enjoy!
6 hours ago, lamtanloc512 said:
Hi MaLdon.
Hey
Use a hackintool, USB tab and create one injector kext usb, remove usbinjectall after that
Olá Madlon, pode me dar uma luz aqui, estou com um Hack Catalina, com quase tudo funcionando, mas não consegui fazer a porta usb tipo c funcionar, alguma dica?
Notebook Dell G7 7588
i7 8750H
patchear o dsdt primeiramente
14 minutes ago, titoneto said:
E qual o processo pra isso?
Extract tables with F4 key in Clover boot screen, boot into system and run this app
26 minutes ago, titoneto said:
esse é o correto
USE ESSA PASTA(sem merge), REINICIA E EXTRAI UM NOVO SENDME
https://filebin.net/sny2st3nia35gj2s/EFI.zip?t=vkw5evgv
tenha um pendrive bootável em mãos, se o boot falhar use o usb
Então, Segue o arquivo, a pasta deu certinho tudo funcionando, Airdrop, audio trackpad, brilho, só que a type c ainda não, ela ate carrega o iPhone, mas não mostra no finder
https://www.dropbox.com/s/xw8nk10ensq00jh/Send me MacBook-Pro-de-Clyto.zip?dl=0
Archive.zip
2 minutes ago, titoneto said:
Uma coisa que não ficou boa foi o Geekbench, piorou MUITO
o gerenciamento e energia está ok, se vc usou o geekbench 4 e agora o 5 vai ter muita diferença, tem de comparar com a mesma versão
