Can anyone help me out ?
I just picked up a Dell inspiron 3521
i5 3337U cpu
8gb ram
intel 4000 grraphics
and I was wondering if anyone has been successful getting this thing to work , maybe share your plist and clover folder?
I made the bootable usb and i keep getting errors , i think its my boot options the flags is not letting me get to the installation screen im trying to get there trying different things but keep getting stuck
[ref]bvrbng777[/ref], post one photo
[ref]bvrbng777[/ref], The last picture with its last log "Still waiting for root device" suggests that USB port/drive is not readable. Try to plug into a different port, preferably a USB 2.0
Donate
Gitter Chat
MSI B360 Gaming Arctic
Thanks for your help and also replying , Yes that was what was wrong : ) I'm able to get to the installation screen but the mousepad doesn't click and I can't install because I need to click and i can't , I plugged in a wired mouse and the usb ports dont recognize it , I tried using tab and control key and I got through to the Catalina select drive to install page and I'm stuck , do you know what might be the problem ?
What is your USB chipset?
Donate
Gitter Chat
My notebook is a Dell Inspiron 3521
Intel core i5 3337u
8gb ram
Intel graphics 4000
I believe it has two usb 2.0 ports and two ss usb ports
Added in 1 minute 12 seconds:
Intel core i5 3337u
8gb ram
Intel graphics 4000
Im trying to install catalina .
Day 5 and i still haven’t figured it out i was able to install catalina but my click doesn’t work and when incpnnect a usb mouse it doesn’t work either
