<IMGUR id="IXayExs"><a href=https://i.imgur.com/IXayExs.png' alt='IMGUR>'>
Everything works except for the audio on jacks, Tried Changing numbers from devices Inject, icon appears but no audio output on the jack.
My ALC is Realtek ALC887 8-Channel HD Audio.
Also from Hacktool it's showing Realtek 867 how to change this?
<IMGUR id="COkMif9"><a href=https://i.imgur.com/COkMif9.png' alt='IMGUR>'>
Motherboard:EMX-IH110LTx-GAMING
CPU: i3-6100
GPU: RX 570
OS: Mac OS Catalina
[ref]theboleslaw[/ref], check with applehdapatcher
[ref]theboleslaw[/ref], if u need use a native audio u need a applehda.kext
All working now I change to inject 11 and patched the latest AppleALC and latest Lilu too. After reboot it worked like a charm! Thank you :)
