Hello Admin, Staff and Other Member,
1. I have problem with cannot shutdown, restart and sleep
2. My UHD 630 cannot accel.
3. my Brightness control not working
4. my battery status not update
here my specs :
Laptop HP Omen 15 DC1090TX
Proc : Intel i7 9750H
GPU : Intel UHD 630
RAM : 16 GB 2666 mhz
HDD : SSD 240 SATA III
Thanks for helping me
Regards,
Fahmi
Send me ms-imac.zip
[ref]TheFahmi[/ref], first u need use a good and correct config, impossible to patch it with ur config
check Olarila clover folder for ur hardware
[ref]MaLd0n[/ref], hello sir. I have Another problem if use orarila clover folder.
Here is an error IOConsoleUsers: gIOScreenLockState 3, hs 0, bs 0, now 0, sm 0x0
I have edited ig platform id and fake id to 0x3e9b0009
[ref]TheFahmi[/ref], yes, use Olarila clover folder and inject ur video properties, reboot and extract one send_me for fine tune
[ref]MaLd0n[/ref],hello Sir, thank you for quick response,
there is an error IOConsoleUsers: gIOScreenLockState 3, hs 0, bs 0, now 0, sm 0x0
<IMGUR id="f4kZA70"><a href=https://i.imgur.com/f4kZA70.jpg' alt='IMGUR>'>
[ref]TheFahmi[/ref], is just a video problem
what ur native dev id and ig-platform-id
[ref]TheFahmi[/ref], check native id/ig-platform-id and change if need
u can try only it too
<key>PciRoot(0)/Pci(0x02,0)</key>
		<dict>
			<key>disable-external-gpu</key>
			<data>
			AQAAAA==
			</data>
			<key>framebuffer-fbmem</key>
			<data>
			AACQAA==
			</data>
			<integer>1</integer>
			<data>
			AAAwAQ==
			</data>
		</dict>
[ref]MaLd0n[/ref], Hi Sir,
thank you for quick reply.
I still got problem,
1. the system detect UHD 620 7 mb, but it must be UHD 630 1538 mb also the system detected i9 processor not i7 processor
2. now there is no sound
3. cannot shutdown, restart and sleep
4. cannot control brightness.
kindly help with this problem
Regards,
Fahmi
Send me Fahmis-MacBook-Pro.zip
[ref]TheFahmi[/ref], with ur config is impossible work on it, is a very wrong, rename, patches, ssdts etc
[ref]MaLd0n[/ref], hello sir,
I have done with config.plist from Olarila
kindly to check and patches
- The system detected i9 not i7
- The system detected UHD 620 7 mb not UHD 630 1538 mb
(I have edit with clover configuration but no result.)
- no sound, no shutdown, no restart, no sleep and no battery.
thank you for helping me
regards,
Fahmi
Send me fahmis-mbp.zip
[ref]TheFahmi[/ref], u need test other config, btw, ur folder is horrible
