[HELP] OS X Mojave Preview not working and more
Hello partners,
It turns out that the preview doesn't work for me on OS X Mojave.
I have been researching forums and there are several ways to solve it, but which one is the most effective and what works?
I have read about changing the SMBIOS to iMac Pro 1.1 and it seems that it also solves iTunes crashed.
What is the most effective way to solve it?
I have the IGC (intel i7-4770K) disabled in the BIOS and I have an RX580.
Thanks for your help.
[ref]cachiputi[/ref],
shikigva=32 shiki-id=Mac-7BA5B2D9E42DDD94
Hello,
But do I need to put the Kext NoVPAJpeg.kext or is it not necessary?
In which section of the Clover Configuration, do I put that?
And I put the iMac Pro 1.1 as SMBIOS?
Thank you!!
[ref]cachiputi[/ref], in boot args
don't need NoVPAJpeg.kext
[ref]cachiputi[/ref], use correct smbios with intel quick sync enable
[ref]cachiputi[/ref], iMac14,2
