Please help: random freeze and reboot when trying to install.
Hi all,
I'm new to the Olarila world and I'm really excited to try it out because it looks to be the most vanilla and has the best support, but I'm having issues installing macOS on my laptop.
I've downloaded Olarila's macOS Catalina image, burnt it onto a USB stick, and followed every step to the letter up to the part where I load up the installer from the USB. (I picked config2). However, I wasn't able to finish the installation. I tried more than 5 times, and each time at a random point the installation will freeze and the machine will reboot and I will have to start again. Please help.
My laptop is a Tongfang GK5CN6Z (Coffee Lake) with Core i7-8750H and integrated Intel graphics and Nvidia GTX 1060 (Optimus).
Thanks.
[ref]SemoB[/ref], Extract tables with F4 key in Clover boot screen, files generated in Clover/Acpi/origin, post here!
[EN]
Dude, I'll get this post to put my problem like this. After my extracted source folder. I changed config.plist in Notepad ++, changing EC0 to EC for 4543305f to 45435f5f .
But it is still giving error as the image below.
<IMGUR id="AjYYGnu"><a href=https://i.imgur.com/AjYYGnu.jpg' alt='IMGUR>'>
_______
[PT-BR]
Cara, eu vou conseguir este post para colocar o meu problema assim. Após a minha pasta de origem extraída. Alterei config.plist no Notepad ++, alterando EC0 para EC para 4543305f [/ b] para 45435f5f [/ b].
Mas ainda está dando erro como na imagem abaixo.
______________________________________________
MacOS: Catalina
Notebook Dell Inspirion 14R 5420
Intel i5 3rd
Intel Graphics HD 4000
GeForce GT 630m (Disabled)
AR9485
No again, following next image:
<IMGUR id="ltbZq8T"><a href=https://i.imgur.com/ltbZq8T.jpg' alt='IMGUR>'>
Any idea ?
MacOS: Catalina
Intel i5 3rd
AR9485
Thanks for the reply [ref]MaLd0n[/ref]. I pressed F4 at the Clover boot screen. Here's a Zip of all that's inside the Origin folder.
I'm hope do work for you. :)
MacOS: Catalina
Intel i5 3rd
AR9485
[ref]douglasdreer[/ref], no idea :shock:
Added in 4 minutes 1 second:
[ref]SemoB[/ref], check if work
@MaLd0n, at least changed the mistake (laughing nervously)...
<IMGUR id="CYPFQTe"><a href=https://i.imgur.com/CYPFQTe.jpg' alt='IMGUR>'>
MacOS: Catalina
Intel i5 3rd
AR9485
Thanks [ref]MaLd0n[/ref], I replaced the DSDT.aml file in the Origin folder with this one. Unfortunately that didn't work. In fact, it made the reboots more frequent. I still can't install macOS. Anything else I can try?
[ref]SemoB[/ref], try with dsdt + Olarila clover folder from here
https://Olarila.com/forum/viewtopic.php?f=28&t=8222
Added in 22 seconds:
[ref]douglasdreer[/ref], sounds like a video kp, framebuffer
[ref]MaLd0n[/ref], I've downloaded the one for SkyLake+ notebooks. It won't even boot into the installer. It gives an ACPI error, method parse/execution failed. AE not found, 20160930/psparse-632.
Update: I've managed to get it to work and successfully install using the above DSDT. Turns out I hadn't chosen it from the Clover boot options before booting.thanks [ref]MaLd0n[/ref].
