No audio from board's sound card with AppleALC
Mojave 10.14.6
AppleALC v1.4.1
Lilu v1.3.8
CodecCommander v2.7.1
Lilu and AppleALC are both installed in /EFI/CLOVER/kexts/Other
My board uses ALC1150
I tried all layouts as boot args, none of them worked
Any pointers please? :)
Thank you
Added in 3 minutes 48 seconds:
@MaLd0n
I forgot we already discussed the subject here and you said you edited codeccommander for ALC1150.
Sadly I can't find it anywhere. Is there a way you could send me a link if you can find it again?
Thank you in advance!
[ref]noisegate[/ref], Working ids are as in this link https://github.com/acidanthera/AppleALC/tree/master/Resources/ALC1150
You should be able to see the intended layout id is successfully injected using ioreg (whether or not audio is working). Can you confirm?
Donate
Gitter Chat
MSI B360 Gaming Arctic
Thanks for your reply, what should I be looking for, where is the injected layout supposed to show?
In this example, layout id 1 is injected. Do note in ioreg the id is shown as HEX.
https://imgur.com/Cl5wfUT
Donate
Gitter Chat
Thanks! Layout id 1 is indeed injected
Here's where I'm at at the moment:
<IMGUR id="wmejXUB"><a href=https://i.imgur.com/wmejXUB.png' alt='IMGUR>'>
indeed you are trying to inject layout id 1. But what does ioreg show?
Donate
Gitter Chat
[ref]noisegate[/ref], change layout id. Reboot. Then look at ioreg if layout id changes. If it does, clover injection is not the issue.
Donate
Gitter Chat
I went for layout id 2, both as a boot arg and in devices > audio > inject
It shows as injected in ioreg, so like you said it's not the issue
Any idea where to look? MaLd0n did mention an edited codeccommander for ALC1150 but I can't find it here or elsewhere.
Thanks again for your time
[ref]noisegate[/ref], As the saying goes, use latest Lilu and AppleALC kexts. Where do you install the kexts? Clover/kexts/other or L/E?
Codec Commander: https://bitbucket.org/RehabMan/os-x-eapd-codec-commander/downloads/
Donate
Gitter Chat
I use latest kexts in the right places (please check original post)
I'm a bit lost... :|
Dont worry. If you are certain you are had not modified native AppleHDA, you are in the right track with Lilu and AppleALC in Clover.
Extract a sendme archive.
Donate
Gitter Chat
ioreg dump keeps failing
Allow permissions in Security Pref
Donate
Gitter Chat
[ref]noisegate[/ref], Looks like audio is enabled with ID 2. Nothing notably wrong in config or ioreg as far as I can see here.
Donate
Gitter Chat
Thank you [ref]onemanosx[/ref], then I don't understand what's wrong.
All I hear are small clicks and pops when I play a file. Same config as what used to work on previous versions of MacOS. Weird...
Maybe go back to the version of AppleALC that works in that previous setup?
Donate
Gitter Chat
