Hi there!
I have a problem installing my GTX 960 in High Sierra 10.13.6 (last version) and i can't get it to work.
I install the webdrivers and when I try to activate the graphics card, i get into a boot loop until i deactivate NvidiaWeb in Clover.
I have tried everything on the web (including Emuvariable and Rc Scripts) and there is no way.
I leave my config.plist in case someone would be kind enough to lend me a hand since I only need the graphics card to work well.
The machine is:
Asus Z97A
i7 4790k
32Gb Ripjaws Z 2100Mhz
Gigabyte GTX 960 G1
Thank you.
config.rar
Hack 2018: Z370 Ultra Gaming 2.0, 8700K, 2x8Gb Corsair Vengeance RGB 3200Mhz, Samsung 970 EVO M.2, GTX 1070 G1 Gaming, Phanteks Eclipse P400S, High Sierra.
Hack 2019: Z370M D3H, 8400, 1x8Gb Corsair LPX 2400Mhz, Samsung 850 EVO SATA, RX 580, Raijintek Styx, Catalina.
Very thanks @MaLd0n going to try and post the results.
EDIT: @MaLd0n i try this, but when i actívate web drivers, the machine enter in a boot loop :(
[ref]xXMulliXx[/ref], what output u use? multi monitor?
HDMI or DVI, no multi monitor
[ref]xXMulliXx[/ref], if u have time use a fresh install and run .command after new install
Ok MaLd0n, im going to this.
Very thanks!
EDIT: At this moment, the hack is runing perfect. Thanks for all MaLd0n :D
