If I find a MB that has a patch does it mean that all functionality works?
I am working on a build but want to use my old 775 socket CPU (e7300)...
I found that I can purchase a GIGABYTE GA-G41MT-S2P at a reasonable price AND there IS a patch in the patch DB. Should I be concerned? (My video card is a ATI 5770) and using on-board sound.
Alternatively I COULD also use another machine which is a MSI P55-GD80 MB with a i760 I also found a patch for this in the Patch DB.
Which is the most compatible based on the patch?
Thanks for your feedback!!!!
Gigabyte is the most used and that ain't for nothing :)
Closest to Mac's hardware.
All 3 DSDT's are made with AutoPatcher and is working 100%.
GA-Z77X-UD5H i7-3770K | 8GB | Gigabyte GTX660 2GB | SAMSUNG PRO 256GB; no DSDT; 10.8.4/10.9 DP8
GA-Z68X-UD3H-B3 | i7-2600K@3.4GHz | 8GB | HD6870 | WD 2TB SATA3 | DP2
GA-P35C-DS3R | Intel Pentium E6500 | 8GB DDR3 | XFX HD 5770 | 10.9 DP8
