Hi guys,
I'm hoping anyone could help me with getting this issue solved.
My spec:
- CPU: i5 4690
- Main: MSI B85-e45
- VGA: RX 570
- DISK: Kington SSD 120 GB
I update the newest bios, and setting to instal hackintosh, but It had never boot to apple logo. :oops:
Maybe clover config is not fit to my mainboard.
Please someone have config list of this main can share for me ?
Thanks you!
[ref]ericpham93[/ref], use Olarila clover folder for ur chipset
[ref]ericpham93[/ref], disable internal graphics for install, use only ur amd card, after u can solve it
:wallbash
Thanks you MaLdOn,
I have a problem when i try to shutdown may pc it RESET
Please help me!
--Run_Me
RunMe.app
[ref]ericpham93[/ref], DSDT.aml.zip
I am sorry, I am replace this file to *Paste edited DSDT.aml in Clover/Acpi/patched folder
But it still not working, Shutdown -> Reset
[ref]ericpham93[/ref], no idea what cause it
[ref]ericpham93[/ref], ur mobo have 3party usb?
[ref]ericpham93[/ref], i'm talking about asmedia usb etc
I solved my problem, some things come with power supply.. Now my pc can shutdown ok
But after sleep, it very slow, very lazzzzz... I can't do any things
Please help me
[ref]ericpham93[/ref], :crazy:
