stakeout5 Posted August 14, 2019 Posted August 14, 2019 Hey all! First and foremost I appreciate everyone's help so far. I had reached the promise land once on my HP Pavilion Laptop 15-cx0056wm with High Sierra so I KNOW it is possible - basically I got, very easily actually, up and running with High Sierra. Frankly my entire EFI went corrupt out of no where and I don't know why so I am doing it all clean - which was no big deal until.... Problem is what I did the first time now all of the sudden it isn't working (yes I backed up my EFI / Clover folder but it isn't working). Same BIOS settings, same steps I followed etc. Attached is my EFI and my specs are below. Mind you this was with a dual boot with Windows 10 and again no issues. Used this guide primarily: https://www.tonycrapx86.com/threads/guide-booting-the-os-x-installer-on-laptops-with-clover.148093/ But I could almost reach the installer (close to it anyways, I got to the screen after all the verbose stuff with the apple and white bar) with either config as long as I used the cpus=1 flag . -- then it sits idle for ever. EFI folder that I'm trying to use for the High Sierra USB: https://drive.google.com/file/d/1NhOUVAzvSBq52amB9myEzhXr02V30u6F/view?usp=sharing Pic of panic: https://photos.app.goo.gl/K95eWMyr3LZ1SiPC9 . (in order) Clover folder from ORIGINAL, previously working install that is no longer working: https://drive.google.com/open?id=1sXYSoj_C9lCG-kh7fEskwsW1zaa6DGHh Read some stuff on threading of my CPU and how HP's have trouble or something? I'm not too sure. I tried to google parts of the KP but not much was related. Wondering why alllllll of the sudden too. BIOS settings pics: https://photos.app.goo.gl/MqaK2pQ7DchgtzS57 My existing install boots to the log in screen perfectly normal then resets the PC out of nowhere now. Here is the EFI folder that is now messed up out of no where (was on my HDD for High Sierra) you can see config.plist is shot... : https://drive.google.com/open?id=1Ekyxw-NlK4exkCIRkKi_odRNvfWAQ8OC Product Specs Product number: 4PY21UA Product name: HP Gaming Pavilion - 15-cx0056wm Microprocessor: Intel® Core™ i5+ 8300H (2.3 GHz base frequency, up to 4 GHz with Intel® Turbo Boost Technology, 8 MB cache, 4 cores) Chipset: Intel® HM370 Memory: 8 GB DDR4-2666 SDRAM (1 x 8 GB) Video graphics: NVIDIA® GeForce® GTX 1050 Ti (4 GB GDDR5 dedicated) + Intel UHD 630 1536 Mb Hard drive: 1 TB 7200 rpm SATA Display: 15.6" diagonal FHD IPS anti-glare micro-edge WLED-backlit (1920 x 1080) HP Imagepad with multi-touch gesture support Wireless connectivity: Intel® Wireless-AC 9560 802.11b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 5 Combo Network interface: Integrated 10/100/1000 GbE LAN Expansion slots: 1 multi-format SD media card reader External ports: 1 USB 3.1 Type-C™ Gen 1 (Data transfer only, up to 5 Gb/s); 3 USB 3.1 Gen 1 (1 HP Sleep and Charge); 1 HDMI 2.0; 1 RJ-45; 1 headphone/microphone combo Thank you for your time.
Administrators MaLd0n Posted August 14, 2019 Administrators Posted August 14, 2019 [ref]stakeout5[/ref], for a good start use Olarila Clover folder for ur chipset https://Olarila.com/files/Clover.Folder/CLOVER.NOTEBOOKS.100.200.300.zip is need apply a video patch after reboot extract one send_me --Run_Me RunMe.app -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
stakeout5 Posted August 15, 2019 Author Posted August 15, 2019 [ref]stakeout5[/ref], for a good start use Olarila Clover folder for ur chipset https://Olarila.com/files/Clover.Folder/CLOVER.NOTEBOOKS.100.200.300.zip is need apply a video patch after reboot extract one send_me --Run_Me RunMe.app [/quo Added in 51 seconds: I will try this tomorrow! Thank.you!
stakeout5 Posted August 15, 2019 Author Posted August 15, 2019 Hi! Here is the Run_ME zip file!!!! If I am able to get my trackpad up and working, sound, and brightness keys - I'd love to send over a nice donation after! Thank you! Send me Michaels-MacBook-Pro.zip
Administrators MaLd0n Posted August 15, 2019 Administrators Posted August 15, 2019 [ref]stakeout5[/ref], check if work EFI.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
stakeout5 Posted August 15, 2019 Author Posted August 15, 2019 Hi! I get stuck at the "End RandomSeed" screen now - no boot. Also sent you 10$ USD : )
Administrators MaLd0n Posted August 15, 2019 Administrators Posted August 15, 2019 [ref]stakeout5[/ref], back to ur previous efi folder, i'll edit ur dsdt -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Administrators MaLd0n Posted August 15, 2019 Administrators Posted August 15, 2019 [ref]stakeout5[/ref], put in clover/acpi/patched, enable patch EC0 to EC in ur config.plist, reboot and extract new send_me DSDT.aml.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
stakeout5 Posted August 16, 2019 Author Posted August 16, 2019 Booted with the patch and the DSDT - here's the file - again thank you. Brightness is available to adjust in my settings, output sound is only "internal speaker" but no sound comes from it, still no trackpad settings - it asks for me to connect an external trackpad (the track pad itself works but is seen as a mouse) - I'm sure you know all of this and are troubleshooting one thing at a time just letting you know as more things come to work. THANK YOU Send me Michaels-MacBook-Pro.zip
Administrators MaLd0n Posted August 16, 2019 Administrators Posted August 16, 2019 [ref]stakeout5[/ref], audio alc295, check here, just inject other layout-id https://Olarila.com/forum/viewtopic.php?f=28&t=9788 ur trackpad work with voodoops2? if no trackpad, is a i2c put two kexts in clover/kexts/other and change trackpad to Advanced mode in bios Arquivo Comprimido.zip run it https://Olarila.com/files/Utils/Kernel%20and%20Kexts%20Cache.command.zip reboot and extract new send_me brightness key i think is q11 and q12, take one shot DSDT.aml.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
stakeout5 Posted August 16, 2019 Author Posted August 16, 2019 Sound and trackpad are functional. (there is NO scroll with trackpad though ), thank you, was wondering if there is a better way to map the brightness keys to F2 for DOWN and F3 for MORE bright? F11/F12 do not work / are linked to iTunes. Thanks. Send me Michaels-MacBook-Pro.zip
Administrators MaLd0n Posted August 16, 2019 Administrators Posted August 16, 2019 [ref]stakeout5[/ref], use fn+brightness key, check if work, if don't work u need a debug, check here https://Olarila.com/forum/viewtopic.php?f=28&t=8396 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
stakeout5 Posted August 16, 2019 Author Posted August 16, 2019 Fn is a no go - I'll check the debug and keep you posted. Thank you! I added the 2 trackpad kexts from above, any thoughts on how to get scrolling to work? Thank you!
Administrators MaLd0n Posted August 16, 2019 Administrators Posted August 16, 2019 [ref]stakeout5[/ref], use dpcimanager and check if device is I2C https://Olarila.com/files/Utils/DPCIManager.app.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
stakeout5 Posted August 16, 2019 Author Posted August 16, 2019 So I got through the brightness stuff well and it all works! Now for the trackpad, I downloaded the tool and opened: I don't see the device listed anywhere... Odd. Please let me know what you think. Thank you. Pics.zip
Administrators MaLd0n Posted August 17, 2019 Administrators Posted August 17, 2019 [ref]stakeout5[/ref], try with this version https://bitbucket.org/RehabMan/os-x-voodoo-ps2-controller/downloads/RehabMan-Voodoo-2018-1008.zip -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
stakeout5 Posted August 17, 2019 Author Posted August 17, 2019 ok I tried, also tried with the newest versions of these: VooDooI2C.kext and VooDooCHID and I tried the FTE one too still no go hmm, odd still no scroll
Administrators MaLd0n Posted August 17, 2019 Administrators Posted August 17, 2019 [ref]stakeout5[/ref], i think ur trackpad is not i2c, u need a voodops2 kext -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
stakeout5 Posted August 17, 2019 Author Posted August 17, 2019 Yes, the result is the same with just VoodooPS2.kext. it's interesting because when I use the voodoops2 kext my settings ask me to set up a Bluetooth trackpad, yet my track pad works
Administrators MaLd0n Posted August 17, 2019 Administrators Posted August 17, 2019 [ref]stakeout5[/ref], in some cases after apply a correct battery patch, trackpad preferences appear -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
stakeout5 Posted August 18, 2019 Author Posted August 18, 2019 Okay cool thank you! May I please ask you for a link to where I can read/see the battery patch? Thanks!
Administrators MaLd0n Posted August 18, 2019 Administrators Posted August 18, 2019 [ref]stakeout5[/ref], https://Olarila.com/forum/viewtopic.php?f=28&t=8208 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
ananjaser1211 Posted August 21, 2019 Posted August 21, 2019 Hey guys, i have this laptop and id like to thank @Mald0n and @stakeout5 for your debugging and work, i first found out about it through a reddit post. High seira might not be the best choice for this laptop imo, jumping to mojave got me full graphics acceleration , and working brightness buttons the stuff i need to fix now are trackpad (which probably wont support gestures due to PS2) ethernet (keeps reconnecting) and the audio which is probably just some kext updates in general. everything else is doing pretty well. my EFI folder is here if you are interested. i am using DSDT Previously patched, and a config.plist merged from various forums P.S My UHD 630 reports full 2048MB on MacBook15,2 smbios . no IGPU hacks needed. native support (https://www.tonycrapx86.com/threads/guide-native-intel-uhd630-graphics-support-in-macos-10-13-6.256426/) EFI : https://drive.google.com/file/d/1MfazgbuPCt0XyW8WYjnnHcBnik0qgJ7V/view?usp=sharing
ananjaser1211 Posted August 21, 2019 Posted August 21, 2019 Update about trackpad. So trackpad gestures and scrolling work when using ApplePS2Smarttouchpad kext from https://drive.google.com/drive/folders/1dMEQja8X3pfXTrmqImQ8L2M1zjp1RDhC It kinda works well, gestures are also supported (4 finger gestures to open and close stuff , vertical and horizontal scrolling too) the main problems with this kext is 1) Mouse acceleration is bad. and no sensitivity control in sight, in fact there is no trackpad settings at all, it won't ask you to connect a trackpad but it will be blank 2) This kext breaks 2 things in our keyboard that are fine in voodoops2controller , it breaks brightness control in f2/f3 and caps lock is weird, it is not dependent on the indicator light, it takes 3 presses to switch from uppercase / lowercase I think maybe voodoops2keyboard extension + appleps2touchpad combo might do us fine. audio wise I fixed it using voodooHDA. however note that the gains need to be modified, it is not as loud as it should. nothing that can't be fixed. everything else on the build is doing fine, even stuff like palm rejection is working. bluetooth works with BluetoothDevBroadcomInjector p.s : again all of this was done on Mojave and not high seira as the post initially was about
