hi guys!!
sadly I'm here for a very annoying problem!
This problem occurred always with finalcut (but I think because finalcut use the GPU)
When I apply some effects on a video usually machine stucks and I have to reboot manually!
This is the log after the crash:
Aug 1 19:43:14 Ruggeros-iMac VTEncoderXPCService[849]: DEPRECATED USE in libdispatch client: Changing the target of a source after it has been activated; set a breakpoint on _dispatch_bug_deprecated to debug
Aug 1 19:43:14 Ruggeros-iMac VTEncoderXPCService[849]: DEPRECATED USE in libdispatch client: Changing target queue hierarchy after xpc connection was activated; set a breakpoint on _dispatch_bug_deprecated to debug
Aug 1 19:43:14 Ruggeros-iMac Final Cut Pro[819]: assertion failed: 18F132: libxpc.dylib + 90677 [9A0FFA79-082F-3293-BF49-63976B073B74]: 0x89
Aug 1 19:43:18 Ruggeros-iMac Final Cut Pro[819]: BUG in libdispatch client: mach_recv, monitored resource vanished before the source cancel handler was invoked { 0x600002697900[source], ident: 246919 / 0x3c487, handler: 0x10d8bb430 }
Aug 1 19:43:23 Ruggeros-iMac Final Cut Pro[819]: DEPRECATED USE in libdispatch client: Clearing handler after the source has been activated; set a breakpoint on _dispatch_bug_deprecated to debug
Aug 1 19:44:57 Ruggeros-iMac com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): Unknown key for integer: _DirtyJetsamMemoryLimit
Aug 1 19:46:38 Ruggeros-iMac syslogd[40]: ASL Sender Statistics
Aug 1 19:50:38 Ruggeros-iMac com.apple.xpc.launchd[1] (com.apple.DumpGPURestart): Service only ran for 1 seconds. Pushing respawn out by 9 seconds.
Aug 1 19:50:49 Ruggeros-iMac com.apple.xpc.launchd[1] (com.apple.DumpGPURestart): Service only ran for 2 seconds. Pushing respawn out by 8 seconds.
Chris on facebook suggested me to take out the NVDIA GPU from the primary pci-e slot.
I do that but the problem is still here.
So Chris suggested me to delete all NVDIA info from clover, but I don't know which one and where.
Also gave me the new lil kext and whatevergreen kext.
Please I can't work like this because every 5 minutes I have to manually reboot!
What you think? Thanks!
[ref]ruglau[/ref], extract one send_me
--Run_Me
RunMe.app
[ref]ruglau[/ref], DSDT.aml.zip
enable IntelHDGraphics and use last lilu+weg kext
So I ha ve to replace your DSDT?
How to enable intelHDGraphics?
Can I reconnect the NVDIA card on the secondary pci-e slot?
Thanks!
[ref]ruglau[/ref], enable in bios
u cxan put ur nvidia, i need disable it via dsdt
use this dsdt above and extract new send_me with ur nvidia connected
Done!
Here is it: https://we.tl/t-2tUErGkTQ1
thanks again!
Added in 3 minutes 11 seconds:
Now I can't open FinalCut (LOL) unaspected closed!
Added in 48 seconds:
FINAL CUT LOG:
Time Awake Since Boot: 670 seconds
System Integrity Protection: disabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Application Specific Information:
/Applications/Final Cut Pro.app/Contents/MacOS/../Frameworks/ProGraphics.framework/Versions/A/ProGraphics
abort() called
[ref]ruglau[/ref], replace full efi, reboot
don't change nothing
EFI.zip
[ref]ruglau[/ref], delete old and put new
ok Maldon, but in kext there are some that I need, like the atheros for the wifi and others.. can I put in your new EFI folder?
also all the usb configuration? I lost all with your EFI?
[ref]ruglau[/ref], u don't need usb config, all ports work with efi above, take one shot
after u add these kexts, use only efi above for we finish fine tune
<IMGUR id="sPZ6SHe"><a href=https://i.imgur.com/sPZ6SHe.jpg' alt='IMGUR>'>
I think only atheros is the one that I need. but I don't know the others.
And sorry Maldon if I ask but why now I don't need usb configuration? It's change something? I know the usb need configuration for the limit of 15 and for work at 3.1 speed!
[ref]ruglau[/ref], this atheros kext is for lan, ur mobo have a intel lan
use this efi and test usb speed
no sorry I forgot to say that I have a WIFI card for wifi. Anyway I added that kext, system work, finalcut work, in gpu info I can see only the AMD card (so I think also DUMP problem is solve) I'll test USB soon :)
For now many many thanks!!!
maldoon same problem after your fix.
LOG:
Aug 19 19:36:46 Ruggeros-iMac syslogd[40]: ASL Sender Statistics
Aug 19 19:44:09 Ruggeros-iMac com.apple.xpc.launchd[1] (com.apple.DumpGPURestart): Service only ran for 1 seconds. Pushing respawn out by 9 seconds.
Aug 19 19:44:20 Ruggeros-iMac com.apple.xpc.launchd[1] (com.apple.DumpGPURestart): Service only ran for 2 seconds. Pushing respawn out by 8 seconds.
Aug 19 19:44:49 --- last message repeated 2 times ---
Aug 19 19:44:49 Ruggeros-iMac com.apple.xpc.launchd[1] (com.apple.DumpGPURestart): Service only ran for 1 seconds. Pushing respawn out by 9 seconds.
Aug 19 19:44:57 Ruggeros-iMac logd[59]: Power button HID event - flushing proactively
Aug 19 19:44:59 --- last message repeated 1 time ---
Aug 19 19:44:59 Ruggeros-iMac com.apple.xpc.launchd[1] (com.apple.DumpGPURestart): Service only ran for 1 seconds. Pushing respawn out by 9 seconds.
Aug 19 19:45:37 localhost bootlog[0]: BOOT_TIME 1566236737 0
Aug 19 19:45:49 localhost syslogd[40]: Configuration Notice:
ASL Module "com.apple.cdscheduler" claims selected messages.
Those messages may not appear in standard system log files or in the ASL database.
Added in 1 minute 45 seconds:
Couldn't be GPU phisical problem?
[ref]ruglau[/ref], if work good, ignore it
