[HELP] Change from i5 to i7 CPU
Hello friends!!
I have changed my i5 CPU to an i7, the BIOS recognizes it perfectly, it works fine.
The problem is that when I start with Clover I get an error and restart the PC alone.
I don't know if I have to change any parameters in Clover, since if I start with the OSX Sierra installation USB connected to the PC and select the SSD where OSX Sierra is always installed, if I can enter and it works fine.
What step do I have to do, for the simple fact of having changed CPU?
Thank you!!
Added in 2 minutes 18 seconds:
by the way, I forgot, I went from an i5-4570S to an i7-4770K
[ref]cachiputi[/ref], drop edited dsdt and check if work, in some cases if we change hardware operation region problem appear
https://Olarila.com/forum/viewtopic.php?f=28&t=9303
if work we need repatch dsdt with new proc
[ref]cachiputi[/ref], dro edited dsdt and check if work, in some cases if we change hardware operation region problem appear
IT WORKS, now what would be the next step, not to depend on the BIOS.eml?
Thanks friend!!
Added in 22 minutes 55 seconds:
sorry, I just read it, as I do to repatch the DSDT ?¿
[ref]cachiputi[/ref], remove old dsdt, reboot and extract new send_me for patch new bios
Hi MaLd0n!
I have deleted the DSDT from the Clover EFI partition.
In the Clover Boot, I still have BIOS.aml.
I have used the Hackintosh Vietnam Tool to create a new SSDT in the / Extra folder. (I don't know if I have done well).
I attached the RunMe to see what you can do.
Thank you!!
Send me iMac-de-Manel.zip
[ref]cachiputi[/ref], DSDT.aml.zip
[ref]cachiputi[/ref], ;):cap
