[ref]kokkolabs[/ref], what hardware?
[ref]kokkolabs[/ref], bad
use Olarila files for one real hackintosh
Ok, i testing with Olarila.
Its installed and evething goes well and easy for now.
Also my Windows and Elementary os boots too :)
But now i have first Refind manager then Clover, but its not big deal for now.
Also my touchpad not work, investigating it later tonight.
[ref]kokkolabs[/ref], i'll check ur files in DSDT Request
With new files it wont boot at all.
I wondering it is easier if i format ssd and install only Mojave? I dont need linux and windows now, so i can install later.
[ref]kokkolabs[/ref], what happens with files?
It stuck after some text, before when it should show loadingbar.
It was some unnallocated space too first on disk which cant delete etc. They left when i did bigger efi-partition.
So i do fresh start, first mojave. Its installing now.
Il be back :)
Edit: i install later only linux, dont need windows :)
Added in 15 minutes 54 seconds:
I can test again after new install?
[ref]kokkolabs[/ref], yes, if dont work, send me one photo with freeze screen
Got working!
Just installing your image and using Clover from another guide witch i linked earlier, everything works on first boot :)
Thank you, i donating you in couple days.. :)
[ref]kokkolabs[/ref], ;)
