Greetings..
Gigabyte Z370 Aorus Ultra Gaming WIFI
i7-9700K
Radeon RX480
Mojave 10.14.5 USB Installer
Using the appropriate Clover Folder (https://Olarila.com/files/Clover.Folder/CLOVER.SERIES.100.200.300.zip) I am unable to boot to the installation via the USB 3.0 Installer. Stuck at the point of the attached picture. Tried most recent Bios F13, F12, and F11 rendering the same results. Also tried with 2nd USB 2.0 Installer with no success. Any suggestions to rectify this issue would be most helpful. Thanks so much! ssprod
Z370 Aorus.pdf
[ref]ssprod[/ref], intelhd enable in bios?
Thank you, Maldon. In reading some posts on your forum, I now understand that XFX GPU's are not good with Mojave, and that is exactly what I have, an XFX RX480. I have removed that card, and can now boot to the installer. I will return the GPU tomorrow.. what brand would you recommend? Thank you, again.
[ref]ssprod[/ref], oh, yes
xfx is not good, people flashed rom from other manufacturer for solve it
