Hello all,
I have a working hackintosh....ok.....but it takes a lot to boot and according to the boot.log there are a few problems.
One of them is a black screen that stays on for a long time.
I would like to ask anyone in this community some help to fine tune my machine.
Boot.log and config.plist attached
bootlog.txt
config.txt
[ref]Pentothal.Z[/ref],
--Run_Me
RunMe.app
EFI.zip
replace full efi reboot
use all hackintosh kexts in clover/kexts/other, don't use system folder like l/e or s/l/e
Thank you very much MaLd0n! I replaced the whole EFI as you said and I have only a few non apple kext in l/e or s/l/e:
RT2870USBWirelessDriver.kext
RealtekRTL8111.kext
MotMobileUSBSwch.kext
MotMobileUSBLANMerge.kext
MotMobileUSB.kext
MotMobileUSB.kext
MotMobileUSB.kext
MotMobileUSB.kext
MotMobileMS.kext
MotMobileMTP.kext
MotMobileUSBLAN.kext
The system is working fine but it still take 1 minute and 40 seconds to get to the login screen.
I guess I have to live with it but if you have more ideas please let me know.
Thanks a lot
P.S. I noticed you use fakesmc instead of virtualsmc.....any particular reason?
[ref]Pentothal.Z[/ref], u can use virtualsmc, no problem
extract new send_me
[ref]Pentothal.Z[/ref], u need avoid duplicate kexts into clover/kexts/other and l/e or s/l/e
check in clover/kexts/other after in l/e or s/l/e
Thanks Mald0n for your help, I checked these directories:
clover/kexts/other
EFI/extra/extensions
l/e
s/l/e
I found only one duplicate: RealtekRTL8111.kext
It was also in l/e and clover/kexts/other. I removed it from l/e.
Still it takes 1 minute and 40 seconds to get to the login screen...........it must be something else.
Cheers!
[ref]Pentothal.Z[/ref], post one photo with -v
[ref]Pentothal.Z[/ref], rec one video in boot using -v, i'll check
ok.......hold on
Added in 21 minutes 57 seconds:
Sorry the file is too large....I need to find a place where I can upload it and then I'll post the link......it's 258MB
[ref]Pentothal.Z[/ref], use ssd
