Hello
I have a problem with Clover. The installation was successful, but my PC boots up to Windows just like before, there is no bootloader.
My specs:
Mobo: MSI H81M-P33
CPU: Intel Xeon E3-1230 v3 (Haswell 4/8 @3,7GHz)
GPU: Palit GTX1050 Ti KalmX
16GB RAM DDR3 1600MHz CL9
SSD: Goodram Iridium Pro 240GB
HDD: HGST 7K1000 1TB
As you can see in the log below, HDD is just for storage, SSD has ~200MB EFI partition, ~200GB for Windows 10, and ~35GB to play with macOS.
I followed this (https://Olarila.com/forum/viewtopic.php?f=50&t=8685) guide to install macOS High Sierra, and I think I'm stuck at point 7. I installed Clover and replaced CLOVER folder with CHIPSET SERIES 5, 6, 7, 8, 9 folder, but I still need to boot the pendrive to access macOS.
Another thing I did is update to 17G7024, so I could install NVIDIA Web Driver, so 1280x1024 doesn't hurt my eyes no more.
Here's the clover install log:
Clover EFI installer log - Sun Jul 21 13:02:22 CEST 2019
Installer version: v2.5k r5018 EFI bootloader
/dev/disk0 (internal, physical):
  #:                       TYPE NAME                    SIZE       IDENTIFIER
  0:      GUID_partition_scheme                        *240.1 GB   disk0
  1:                        EFI EFI                     231.1 MB   disk0s1
  2:       Microsoft Basic Data SSD                     205.1 GB   disk0s2
  3:                 Apple_APFS Container disk2         34.7 GB    disk0s3
/dev/disk1 (internal, physical):
  0:      GUID_partition_scheme                        *1.0 TB     disk1
  1:       Microsoft Basic Data HDD                     936.2 GB   disk1s1
  2:       Microsoft Basic Data Backup                  64.0 GB    disk1s2
/dev/disk2 (synthesized):
  0:      APFS Container Scheme -                      +34.7 GB    disk2
                                Physical Store disk0s3
  1:                APFS Volume macOS                   11.9 GB    disk2s1
  2:                APFS Volume Preboot                 41.4 MB    disk2s2
  3:                APFS Volume Recovery                1.0 GB     disk2s3
  4:                APFS Volume VM                      20.5 KB    disk2s4
/dev/disk3 (external, physical):
  0:      GUID_partition_scheme                        *15.5 GB    disk3
  1:                        EFI EFI                     209.7 MB   disk3s1
  2:                  Apple_HFS Olarila High Sierra ... 7.7 GB     disk3s2
Target volume /Volumes/macOS on disk2 is APFS on physical store disk0s3
Backing up EFI files
Backing up /Volumes/macOS/EFIROOTDIR/EFI folder to /Volumes/macOS/EFI-Backups/r4920/2019-07-21-13h02/EFI
Installing BootSectors/BootLoader
Stage 0 - Don't write any of boot0af, boot0md, boot0ss to /
Stage 1 - Don't write any of boot1h2, boot1f32alt, boot1xalt to /
=========== Clover EFI Installation Finish ===========
Does it mean a successful installation? As for me, it looks like something is missing?
What should I do obtain a dual boot macOS + Windows 10?
Thank you
[ref]qyh[/ref], if u use dual boot with 2 hdd/ssd, just put Olarila efi folder into macos hdd/ssd and set to primary boot in bios/uefi
don't need install clover
So can I reinstall macOS to HDD and keep Windows on SSD, and both of them will be bootable from UEFI?
[ref]qyh[/ref], yes
Wow, it really worked! I tried to get it working last year, but I failed and lost about a week for that. And someone told me that Windows and macOS must be on the same disk, otherwise it's impossible to boot each of them.
I sent a DSDT patch request. Do I need to make any configuration after I paste the obtained file? Some changes in config.plist or anything
like that? Is it possible to get Apple services working?
