[Guide] Mobile Intel HD Graphics / Clover or Opencore
How to fix Mobile Intel HD Graphics / Clover or Opencore
-Problems with Paypal HERE
-Installation Guide HERE
-Hackintosh EFI folders HERE
-Hackintosh USB Remap HERE
Mandatory Files: Lilu and WhateverGreen kexts
Apply Patch in Devices Properties in your config.plist / Clover or OpenCore
If you need some extra properties on these patches check HERE
Use Olarila EFI folders
Add bootargs igfxonln=1 and agdpmod=vit9696
-HD4600, 4400 and 4200
Quote
            <dict>
                <data>BgAmCg==</data>
                <key>device-id</key>
                <data>EgQAAA==</data>
                <key>framebuffer-cursormem</key>
                <data>AACQAA==</data>
                <integer>1</integer>
                <key>hda-gfx</key>
                <string>onboard-1</string>
            </dict>
-HD5000, 5100 and 5200
Quote
            <dict>
                <key>hda-gfx</key>
            </dict>
-HD5300, 5500 and 6000
Quote
            <dict>
                <data>BgAmFg==</data>
                <key>framebuffer-fbmem</key>
                <data>AAAwAQ==</data>
                <key>hda-gfx</key>
            </dict>
-HD5600
Quote
            <dict>
                <data>JhYAAA==</data>
                <key>hda-gfx</key>
            </dict>
-HD515, 520, 530 and 540 6th Gen
Quote
            <dict>
                <key>AAPL,GfxYTile</key>
                <data>AQAAAA==</data>
                <data>AAAbGQ==</data>
                <key>hda-gfx</key>
            </dict>
-HD550 and P530
Quote
            <dict>
                <data>AAAmGQ==</data>
                <data>JhkAAA==</data>
                <key>hda-gfx</key>
            </dict>
-HD615, 620, 630, 640 and 650 7th Gen
Quote
            <dict>
                <data>AAAbWQ==</data>
                <data>FlkAAA==</data>
                <key>hda-gfx</key>
            </dict>
-HD620 and 630 8th Gen
Quote
            <dict>
                <data>CQClPg==</data>
                <data>pT4AAA==</data>
                <key>hda-gfx</key>
            </dict>
-HD620 and 630 9th and 10th Gen
Quote
            <dict>
                <key>igfxfw</key>
                <data>AgAAAA==</data>
                <key>hda-gfx</key>
                <data>AACbPg==</data>
                <data>mz4AAA==</data>
            </dict>
-IceLake 10th Gen
Quote
            <dict>
                <data>AABSig==</data>
                <data>UooAAA==</data>
                <key>disable-external-gpu</key>
                <key>enable-hdmi20</key>
                <key>framebuffer-unifiedmem</key>
                <data>AAAAgA==</data>
                <key>hda-gfx</key>
                <key>igfxfw</key>
            </dict>
-Generic Patch
Quote
            <dict>
                <key>hda-gfx</key>
            </dict>
Credits and Thanks: Slice, RehabMan, vit9696, headkaze
We're all here to have fun and learn from each other! That's all Folks!
  • Like 6
  • Thanks 2
:superman:superman:superman
:superman:superman
[ref]Nishrox[/ref], [ref]erroruser[/ref], :mrgreen::meeting
[ref]mathewgx[/ref], is a UHD620 from coffelake processors, i'll update topic
[ref]onemanosx[/ref], :guitar:cap
[ref]brunoyagamii2[/ref], config.plist.zip
[ref]brunoyagamii2[/ref], é só vc substituir na pasta efi que fica na partição efi
Eu não consigo iniciar o Mac, como vou copiar esse arquivo e colocar numa partição, se eu não tenho sistema operacional. :?
Eu vou mover esse arquivo para a EFI do Mac que eu estou instalando, CORRETO?
[ref]brunoyagamii2[/ref], na tecla O vc pode editar todas as configs do clover
[ref]aria92[/ref], if u use a desktop, InjectIntel and 0x19120000 solve
Hi, any idea how to fix scaled blurs, gradients and dashboard glitches when adding widgets ?
laptop HP i5 KabyLake HD620.
At the moment I'm using this trick to solve this problem (but maybe you have better solution) :
Boot > Arguments -----> lilucpu=8
Devices > Properties > Devices > PciRoot(0)/Pci(0x02,0)
Devices > Properties > Properties Key > AAPL,ig-platform-id with in Properties Value > 00001619
Devices > Properties > Properties Key > device-id with in Properties Value > 16190000
Graphics > set ig-platform-id to 0x19160000
Graphics > enable Inject intel
About that Mac shows HD620, but OpenGL Extension viewer says it's Intel Iris Graphics 550 ( well at least got nice depths colours and gradients)
thanks in advance
