[Guide] Mobile Intel HD Graphics / Clover or Opencore
4 hours ago, zackcr7 said:
just a last a question I have a nvdia rtx 2080 super
this card dont work, use -wegnoegpu to disable it on-the-fly
1 hour ago, zack Elbaitil said:
i tried all that and other things but stuck on black screen or gioscreenlockstate 3 hs 0 bs 0 now 0 sm 0x0 or other thing
what processor?
SUCCESS Big Sur Hackintosh
My Config
Z490 Aorus Master
i7-10700K
16GB DDR4 3000 MHZ
intel UHD 630 iGFX with Nvidia RTX 2080 Super PCI x16
To Fixe HDMI black screen ADD THIS to your config.plist
Monitor now work with HDMI
    <key>Add</key>
    <dict>
        <key>PciRoot(0x0)/Pci(0x1C,0x4)/Pci(0x0,0x0)</key>
        <dict>
            <key>device-id</key>
            <data>
            8hUAAA==
            </data>
        </dict>
        <key>PciRoot(0x0)/Pci(0x1f,0x3)</key>
        <dict>
            <key>layout-id</key>
            <integer>11</integer>
        </dict>
        <dict>
            <data>
            BwCbPg==
            </data>
            <data>
            mz4AAA==
            </data>
            <key>framebuffer-con0-busid</key>
            <data>
            AgAAAA==
            </data>
            <key>framebuffer-con0-enable</key>
            <data>
            AQAAAA==
            </data>
            <key>framebuffer-con0-flags</key>
            <data>
            xwMAAA==
            </data>
            <key>framebuffer-con0-index</key>
            <data>
            AgAAAA==
            </data>
            <key>framebuffer-con0-pipe</key>
            <data>
            CgAAAA==
            </data>
            <key>framebuffer-con0-type</key>
            <data>
            AAgAAA==
            </data>
            <key>framebuffer-con1-busid</key>
            <data>
            BAAAAA==
            </data>
            <data>
            AQAAAA==
            </data>
            <key>framebuffer-con1-flags</key>
            <data>
            xwMAAA==
            </data>
            <key>framebuffer-con1-index</key>
            <data>
            AwAAAA==
            </data>
            <key>framebuffer-con1-pipe</key>
            <data>
            CAAAAA==
            </data>
            <key>framebuffer-con1-type</key>
            <data>
            AAgAAA==
            </data>
            <key>framebuffer-con2-busid</key>
            <data>
            AQAAAA==
            </data>
            <data>
            AQAAAA==
            </data>
            <key>framebuffer-con2-flags</key>
            <data>
            xwMAAA==
            </data>
            <key>framebuffer-con2-index</key>
            <data>
            AQAAAA==
            </data>
            <key>framebuffer-con2-pipe</key>
            <data>
            CQAAAA==
            </data>
            <key>framebuffer-con2-type</key>
            <data>
            AAQAAA==
            </data>
            <key>framebuffer-fbmem</key>
            <data>
            AACQAA==
            </data>
            <data>
            AQAAAA==
            </data>
            <data>
            AAAwAQ==
            </data>
        </dict>
        <key>PciRoot(0x0)/Pci(0x1,0x0)/Pci(0x0,0x0)</key>
        <dict>
            <key>IOName</key>
            <string>#display</string>
            <key>class-code</key>
            <data>
            /////w==
            </data>
            <key>name</key>
            <data>
            I2Rpc3BsYXk=
            </data>
        </dict
Add only darkwake=0 to bootarg no other things
my kexts are APPLEALC, FAKEPCIID Intel I 225-V, FAKEPCIID, USBINJECTALL, iTLWM, LILU, SMCPROCESSOR, SMCSUPERIO, USBPORTS, VIRTUALSMC, WHATEVERGREEN
THANKS FOR YOUR HELP
4 hours ago, Queen Qin said:
I'm on big sur with clover 5126 version
first go to one good and clean folder
https://www.olarila.com/topic/5676-folders-for-all-chipsets-clover-and-opencore/
u can use for desktop, put correct smbios and voodoops2controller
6 hours ago, lightpower said:
For Comet Lake 10th gen Desktop?
			<dict>
				<data>BwCbPg==</data>
				<data>mz4AAA==</data>
				<key>enable-hdmi20</key>
				<data>AQAAAA==</data>
				<data>EgAAAA==</data>
				<data>EAAAAA==</data>
				<data>AAgAAA==</data>
				<key>framebuffer-unifiedmem</key>
				<data>AAAAgA==</data>
				<key>hda-gfx</key>
				<string>onboard-1</string>
			</dict>
			<dict>
				<key>hda-gfx</key>
			</dict>
Eventually it did not work, as soon as it boots it flies blackscreen
add igfxonln=1 with this patch
4 hours ago, lightpower said:
Hello @MaLd0n with igfxonln=1 in active. again black screen after boot.
create patch
1 minute ago, lightpower said:
With Hackintool? How?
tab Patch/Patch
I applied HD620 and 630 8th Gen patch but still have 7 MB Intel HD 630 mobile ?  Mojave 10.14.6
msi GE63 Raider
Intel Core i7-8750H with Intel HD 630 and (GTX 1070 disabled)
16GB RAM
EDIT: My config file
config.plist.zip
Edited by RandomTech
Haswell Hackintosh: GA Z970N WIFI Gaming 5, i7 4790K, Radeon HD 7970, 16GB RAM
Coffee Lake Hackintosh: GA Z370N Wifi, i7 8700K, Radeon XFX RX Vega 64, 32GB RAM
U need check if processor is kabylake r, cooffelake, whiskeylake
