[Guide] Mobile Intel HD Graphics / Clover or Opencore
1 hour ago, Arturo Miranda said:
not work for hd4400 laptop on catalina
work. tested many times. i some cases u need a connectors for hdmi output work
the last answer in this post
its works perfect!!
thanks!!!
Edited by Arturo Miranda
me
3 hours ago, josesach2133 said:
how and where should I paste the text?  I open it with the propertree and clover configurator but I don't know where to put it, can you help me?
devices properties
what ur processor?
57 minutes ago, AmazingHarsh said:
Where should I paste the above code
devices properties
u need create
Olá, boa tarde. O patch Genérico de vídeo serve para todas as versões de intel Graphics HD, inclusive as não suportadas, ou só pra não suportadas?
Obrigado.
Não
I tried to insert the patch for HD620 Ice Lake but I got the result as in the picture .. did I do something wrong? I attach config and screenshots. Can you check if I entered the data correctly .. thanks
Archivio.zip
Edited by cesare
4 hours ago, zack Elbaitil said:
what about i7-10700k intel UHD 630 Comet lake motherboard z490 aorus master
Quote
            <dict>
                <data>BwCbPg==</data>
                <key>device-id</key>
                <data>mz4AAA==</data>
                <key>enable-hdmi20</key>
                <data>AQAAAA==</data>
                <key>framebuffer-con0-enable</key>
                <key>framebuffer-con0-pipe</key>
                <data>EgAAAA==</data>
                <key>framebuffer-con0-type</key>
                <data>EAAAAA==</data>
                <key>framebuffer-con1-pipe</key>
                <key>framebuffer-con2-pipe</key>
                <key>framebuffer-con2-type</key>
                <data>AAgAAA==</data>
                <key>framebuffer-unifiedmem</key>
                <data>AAAAgA==</data>
                <key>hda-gfx</key>
                <string>onboard-1</string>
            </dict>
add igfxonln=1
just a last a question I have a nvdia rtx 2080 super
so in the bios settings I must leave it pci slot 1 or change it to igfx ?
and I must use an HDMI directly to the motherboard ? because I sue a DP injected to my Nvidia
thanks fo your help
