[Guide] Mobile Intel HD Graphics / Clover or Opencore
2 hours ago, Jesus Manuel Cocaño Diaz said:
I am very new in this hackintosh, I do not understand how to make the video patch, I am stuck in this step in the oralia tutorial, I have a UHD620 from Whiskey lake
into devices properties, use one txt app like TextMate
Hi,
After two weeks of trying to install Catalina on my HP ENVY 34 AIO desktop,  I finally got Catalina up and running thanks to your  config.plist.   There are two issues I have right now.  1. There's no sound  (ALC293). 2. When booting with the second monitor plugged in,  I get black screen on the main monitor and video on the second.    In order for dual monitor to work properly,  it has to boot with a single monitor then hot plugging the second one.  Any help  would be appreciated.
trouble shooting attempts
changing layout id with alcid= 11,28,29
used hackintool to created patches
changing platform id
HP ENVY AIO 34 CURVED
i7-7700 Kaby Lake
HD 630
Edited by dan ng
if u have a radeon rx460 u dont need it
Ok any idea how I can get dual monitors and sound to work properly?
UHD 620 on Comet Lake i5-10210U (Huawei Matebook X Pro 2020) here.
Tried all kinds of different platform-id and device-id combinations, I simply cant get this to work. Config from the OP post ends in a blackscreen.
If I attach a USB-C Monitor I can see that iGPU acceleration is enabled with the configs that give me a black screen but I simply cant get the laptop monitor to work.
I can see this line while booting, maybe its related:
agdc backlight control did not find dp micro
Bildschirmfoto-2020-07-25-um-00-26-58.pn
3 EFI BATTERY PATCHED NO TRACKPAD LATEST.zip
Edited by Killuminati91
if u have a comet lake not refresh,. this patch is a mistery for now
2 hours ago, Hisham.. said:
Intel hd 4000 how i can fix it
check first post
check first post
I can't find hd 4000 or 4600 and 4400 will work ?
if don't have in first post check rehabman repo
Essa kry vai dentro da Graphics? Substitui o conteudo? Desculpa, sou novo nisso. A minha placa eh uma 630 7a gen, e fica mostranto 7 MB de memohria.
se for desktop vc tem de criar com o hackintool
17 hours ago, TuranUl said:
HD4000 ?
use hackintool and create one for this igpu
7 hours ago, filler said:
Isnt there an UHD630 9th genetarion file?
use 0x3E9B0007 and igfxonln=1
5 hours ago, swh123 said:
Screen Shot zip.zipThank you so much, but no chance for HD 2000?
no
  • Sad 1
5 hours ago, marcopolo007 said:
i dont see INTEL HD 4000 ? can you please help..
hey
check rehabman repo for hd4000
