[Guide] Mobile Intel HD Graphics / Clover or Opencore
1 hour ago, Saikumar Reddy Mallela said:
there is no 9th gen UHD 630 file ( i7 - 9750H ), Could you please tell me which one should i try with?
first shot is a "generic patch"
Is there any for intel hd 2500 ? I installed Catalina in my Lenovo g700 , everything works except the graphic acceleration , is it possible in Catalina or I need to install high Sierra , Thanks Maldon
no idea about this igpu
1 hour ago, iNikjee said:
For Intel HD 505?
i think not work
hi guys, I have aorus z390 pro and i9 9900k cpu.
i already use this for a while and stable.
then I update it to 10.15.5 then I got black screen.
then when I delete the devices properties. it worked again but my Graphics become 7mb.
can anyone help me please?
thanks
10.15.5 broke things about video, hdmi
is there any way I can fix this? or should I need to buy video card?
Edited by saintran josh
to prevent spam the forum
wait some days for solution
É possível converter o properties (patch do vídeo) feito pelo Hackintool e colocar no OpenCore? Se sim, como fazer?
é o mesmo, use um textmate para editar
4 hours ago, Shaheenyrn said:
Hi , which one for graphics 2000 ?
i think don't work
u.u i have hd520, i try with pci info but after reboot only give me a line "Graphics driver failed to load: could not register with Framebuffer driver!", i open config.plst with clover configurator, smbios check mbp 13.1. My bby Lenovo ideapad 300 14lsk Core i3 6th 8gb ram   intel hd520
u apply patch from first post?
I use the -igfxvesa argument to initialize my hackintosh with intel UHD 630 graph. If I use this video patch, do I need to continue with this argument in config.plist?
no
this arg put igpu in vesa mode
