[Guide] Mobile Intel HD Graphics / Clover or Opencore
[ref]Zarach[/ref], abre com um app txt e substitui o patch que já tem lá e não use injectintel ou qq outro patch relacionado ao vídeo
Ok, fui substituindo e testando.
O processador eh de oitava geracao, mas a placa de video eh de setima geracao.
Ativou, mas so o monitor externo aparece a tela. E tah tudo rosa.
Minha smbios tah imac 18.1
Qual smbios voce recomenda que eu use?
HahAhAH
10 hours ago, eka indrayana said:
hello i have some problem with my intel hd 530 in catalina 10.15.4
apple change many things in 10.15.4, but i dont have any problem, check google
9 hours ago, eka indrayana said:
hiii i already found the solution with change the properties in device section in my config.plist
ok, but ur config is very wrong
3 minutes ago, eka indrayana said:
could you advise me where is the wrong?
use Olarila folder with video patch and embedded controller rename
I have an alienware 17R4 with a geforce gtx 1080 card and another onboard intel hd 630. However the screen is GSYNC and therefore I am not able to activate the intel card and install it in the Catalina version. Is there a way to activate this card or will it only work in High Sierra with both cards active?
u can disable nvidia card via bios?
2 hours ago, ChickenJoeJoe said:
How do i Apply the config.plist?
check first post
1 hour ago, ninjasptifire said:
No. I don't have that option.
no way
