[Guide] Mobile Intel HD Graphics / Clover or Opencore
42 minutes ago, Srdjan Blagojevic said:
How can I get second screen working on my HP G1 800 SFF Hackintosh? My second screen doesn't even detected.
enable csm
Hi MaLd0N
HD620 and 630 9th Gen.   Is this for only Laptop? or Desktop also?
Can you help me Patch for  i5-9600k, iGPU, Desktop model?   MB: GB, z390i Aorus Pro Wifi...
Appreciate with your help....
mobile only
check hackintool
Hello, I have an HP I5 6600 with intel hd 530 graphics, I have applied the patch and the graphics work(1536megas), but the problem is that for it to detect it, I have to disconnect the hdmi and reconnect it, it starts up perfectly, it reaches the loguin screen, it looks like half a second and enters as in sleep mode, but nevertheless the hard disk light blinks continuously, only by disconnecting the hdmi cable and reconnecting it is how I can get it to work.The cable that I use is DP (in the cpu) to HDMI in the monitor, in case that influences
Edited by goliat22
Quote
            <dict>
                <key>#framebuffer-patch-enable</key>
                <data>AQAAAA==</data>
                <data>AAASGQ==</data>
                <key>device-id</key>
                <data>EhkAAA==</data>
                <key>framebuffer-unifiedmem</key>
                <data>AADw/w==</data>
            </dict>
12 minutes ago, MaLd0n said:
I mean change this one you gave me for this one: <key>PciRoot(0x0)/Pci(0x2,0x0)</key>
            <dict>
                <key>AAPL,GfxYTile</key>
                <data>AAAbGQ==</data>
                <key>framebuffer-fbmem</key>
                <data>AACQAA==</data>
                <integer>1</integer>
                <data>AAAwAQ==</data>
                <key>hda-gfx</key>
                <string>onboard-1</string>
            </dict>
and add bootargs agdpmod=vit9696 and igfxonln=1 and igfxagdc=0
Enjoy!
Hi,
I installed macos Monterey on my HP Prodesk 600 G1 DM with  i3-4130 and Intel HD Graphics 4400 iGPU.
When I use device-id=160a000c and AAPL,ig-platform-id=0c00160a in my opencore config.plist it boots ok, but whitwout graphic acceleration and only 7mb vram. I tried with the patch from first page and it boots with graphic acceleration, but when I login It freezes on desktop after few seconds. How to fix it?
https://github.com/acidanthera/WhateverGreen/blob/master/Manual/FAQ.IntelHD.en.md
Good night, how are you?
I have an HP 250 G8 with i5 ice lake processor, the IGPU works, but it doesn't activate the HDMI, I already got the patch here and nothing, any tips?
HDMI don't work on Icelake
2 minutes ago, DarkWolf_hun said:
What the fuck is this? Why don't save the fucking config? ?
use one txt app like TextMate
I tried to do this with it saying that it failed to read the configuration, to be honest its kinda vague on what your actually suppose to do, are you suppose to add the code to the existing code there? or replace the previous code it had.
Edited by Mr random music
first what ur hardware?
I have a dell inspiron 5767 with 12gb of ram, a 1tb ssd (just put it in today replaces hdd), and a intel core i5 7th gen with a intel had 620 igpu
