I installed high Sierra on my system, i5 2500k, p67 pro3, ati 6870 and I'm facing this 2 issues:
-RunMe.app gets always stuck on "CPU log" and cannot finish the process.
-If I plug my 1tb ntfs external drive the system freeze BUT if I boot the pc with the drive already plugged in, it works.
I followed the step by step tutorial and I've only added the kext to have the temperature. sensors working with FakeSMC.
[ref]asdfgh00[/ref],
run in terminal, reboot and extract again
sudo log erase --all
ntfs use tuxera
ntfs use tuxera
I know that I cannot write on rtfs without texture but I would like to avoid the freeze.
Sorry but I'm new to hackintosh, what should I extract after running that command and reboot?
edit: I've started again RunMe after erasing the logs and reboot but it's still stuck on Cpu log
