Hackintosh Guide - Catalina / Big Sur / Monterey on Mobos Series 100, 200, 300, 400 and 500 with OpenCore Bootloader
[ref]ekomy[/ref], don't exist all in one solution in hackintosh, if don't work for u u need check what cause problem and solve
[ref]steezy[/ref], DSDT.aml.zip
[ref]steezy[/ref], hackintool
Using my clover configurator to Inject Nvidia, graphics info shows completely. I don't know how to do this on OpenConfigurator config to Inject Nvidia, sorry for dumb question :wallbash
Bom dia MaLd0n,
Também queria experimentar o OC no meu sistema ;)
Utilizei o EFI deste tópico e anexo aqui o "Send me iMac-Pro.zip" resultante.
Também anexei o EFI do CLOVER que utilizo para sua referência, com o DSDT.aml que você criou...
Obrigado.
EFI.zip
♦︎ SMBIOS: MACPRO6,1  ♦︎ SO/OS: Catalina 10.15.5 (19F101) + Windows 10 (64bits) ♦︎ PM/MB: Gigabyte Z390 Aorus Xtreme (Bios=F9C & MSR unlocked) ♦︎ CPU: Intel i9 9900K ♦︎ COOLER: NZXT Kraken X73 ♦︎ RAM: TeamGroup 32GB DDR4@3200Mhz ♦︎ PSU: Corsair 1000W HX1000i ♦︎ NVME: Samsung SM961 512GB ♦︎ HD: 1TB (SATA) + 2 x 4TB (SATA) + 8TB (USB3) ♦︎ SSD: 1 x Crucial CT960M500 1TB ♦︎ VIDEO: Sapphire Radeon VII 16GB c/HDMI p/ TV Panasonic 58" 4K/HDR/3D ♦︎ SOM/SOUND: ALC1220 ♦︎ MONITOR: Dell SP2309W + 2 x Samsung S24E450 ♦︎ THUNDERBOLT: (onboard) Titan Ridge  ♦︎ WLAN\BLUETOOTH: Broadcom BCM943602CS ♦︎ TECLADO/KEYBOARD: Apple Wireless Keyboard A1314 ♦︎  RATO/MOUSE: Apple Wireless Touchpad A1339 ♦︎ WEBCAM: Logitech HD Pro C920
[ref]augustopaulo[/ref], Arquivo Comprimido.zip
Obrigado pelos ficheiros! ;-)
Coloquei-os em EF/EFI/OC/ACPI, mas perco todas as portas USB ao chegar à janela de login!
Tentei arrancar somente com o DSDT.AML mas o resultado é o mesmo...
Podes, por favor, dar outra olhada ?
[ref]augustopaulo[/ref], use usbinjectall or native usb fix via ssdt oem
Good morning,
Managed to get my USBs back by adding:
  • USBInjectAll.kext into EFI/EFI/OC/Kexts
  • "uia_exclude=HS14" into config.plist/NVRAM/7C436110-AB2A-4BBB-A880-FE41995C9F82/boot-args - to disable CNVW Intel
    bluetooth device
Will try to look into your DSDT.aml to see if I can add the thunderbolt part...
Thanks for help!
Boa sorte,
Paulo
[ref]x3tab[/ref], DSDT.aml.zip
[ref]Abdulraheem[/ref], u use some ssdts etc, not good
Added in 1 minute 12 seconds:
[ref]TwistedSystems[/ref], u need extract files with open core running, clover have some diff about regions fix etc
[ref]TwistedSystems[/ref], here we go
