Hackintosh Guide - Catalina / Big Sur / Monterey on Mobos Series 100, 200, 300, 400 and 500 with OpenCore Bootloader
[ref]chhaggerty[/ref],
EFI CLOVER, just replace, have all u need inside folder
EFI Clover.zip
EFI OC
EFI OC.zip
after reboot need extract send_me for dsdt patch
use bios/uefi in default, just need enable intelHDGraphics in chipset tab if u need IntelQuickSync and CSM if u have black screen
I'm happy to report I was able to boot my Catalina SSD partition with EFI OC.zip, although it didn't see my NVME Mojave partition. Was able to run "RunMe.app", and here is the Send me file... Thanks, it's cool getting my first OC boot with your help.
Send me z370-Aorus.zip
[ref]chhaggerty[/ref], check if work, put in OC/ACPI
[ref]yamazaki45[/ref], audio check my sig, useful links
My SIG ?
I did not understand...
but I am wanting the DSTS because I do not know how to do it or if possible someone help me to do it, because I believe that with it I solve the problem of 3.5MM
Send me, may have some information ....
[ref]yamazaki45[/ref], sig = signature ;)
Olá MaLd0n será que vai rodar bem na minha maquina?
Melhor do que o Clover? Já tentei de varias formas inicializar é muito complexo não estou conseguindo.
Poderia por gentileza me da uma ajudinha!!!
Para conseguir rodar com o Catalina tive que mudara placa de video para EVGA NVIDIA GeForce GTX 650ti 2 GB.
Também gostaria de saber sobre a sua placa de video estou querendo fazer um upgrade.
Olá MaLd0n estou querendo instalar wifi na minha maquina o que acha de placa?
https://pt.aliexpress.com/item/32954222580.html?spm=a2g03.12057483.0.0.1ed56829jdC1Kl
Identificador do modelo: iMacPro1,1
Placa Mãe: Asus TUF Z390-PLUS GAMING (WI-FI)
conjunto de chips: Intel Z390
Memoria RAM: 1x16 GB Corsair 3000 MHz DDR4
Processador: Intel Core i7-8700K 3.70GHz
Placa de Video: Sapphire Radeon RX 590 NITRO+ Special Edition Dual, 8GB
Wireless/Bluetooth: BCM943602CS 16000Mbps 802.11AC
[ref]talmazi[/ref], estou usando a rx590, nativa
esse wifi tb é nativa
-UPDATE FIRST POST-
Full EFI folder
[ref]ygtaldmr[/ref], this topic is about OpenCore
[ref]ygtaldmr[/ref], u need use EFI folder from first post and extract send_me with this folder
[ref]ygtaldmr[/ref], put in ssd/hdd
