Administrators MaLd0n Posted November 17, 2020 Author Administrators Posted November 17, 2020 for now use -igfxvesa and check if work -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
thetwoangels Posted April 10, 2021 Posted April 10, 2021 Hola Maldon. No me funciona el ratón en el GUI de OpenCore (V 0.68). ¿Alguna forma de activarlo y hacer que funcione en el GUI (pantalla de inicio)? Gracias. Saludos Intel Core i5-4460S Chipset H81 Intel Graphics HD4600 SSD240Gb 16Gb RAM Mitac PH11LI Motherboard
anto barreca Posted April 10, 2021 Posted April 10, 2021 13 minutes ago, thetwoangels said: Hola Maldon. No me funciona el ratón en el GUI de OpenCore (V 0.68). ¿Alguna forma de activarlo y hacer que funcione en el GUI (pantalla de inicio)? Gracias. Saludos Intel Core i5-4460S Chipset H81 Intel Graphics HD4600 SSD240Gb 16Gb RAM Mitac PH11LI Motherboard you have to set in Misc / Boot / PickerAttributes = 17 ?
thetwoangels Posted April 10, 2021 Posted April 10, 2021 6 hours ago, anto barreca said: you have to set in Misc / Boot / PickerAttributes = 17 ? Thank you. If true, in the last configuration I was guided by a tutorial for the GUI with images and changed the 17 to a 1. Greetings.
jasperlevi Posted May 4, 2021 Posted May 4, 2021 Hey @MaLd0n Thanks for this amazing forum, and all the good work you are doing to help Hackintoshers worldwide. I am facing a problem, trying to help a friend install Catalina with your EFI folder (EFI OpenCore Serie 300.400.zip). His hardware is: Gigabyte Z490M Gaming X motherboard with latest F20 BIOS revision Intel i7 10700K processor Samsung 1 TB M.2 NVME drive 32 GB Corsair Vengeance DDR4 3200 RAM He has Windows on his machine, and he is trying the Windows method from the Dortania website, to create his installer USB. The problem is that we are (at best) able to get the USB to boot, but when we choose the installer option, we get the Apple logo with the progress bar below it, and it disappears after about 40% progress, and then the screen goes black. Nothing happens. We have tried EFI folders from other people who have successfully installed Catalina on their Z490 boards, but somehow are getting stuck at this point. We are hoping that you will be able to help us out of this problem and get Catalina installed on my friend's machine. Thanks in advance...
Administrators MaLd0n Posted May 4, 2021 Author Administrators Posted May 4, 2021 1 hour ago, jasperlevi said: Hey integrated video? if yes use -igfxvesa and change smbios -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
clockT Posted May 23, 2021 Posted May 23, 2021 i can't go on after booting with opencore. i downloaded version "Big Sur 11.3.1 with EFI folder for chipset series 300, 400 and 500" and put EFi of chipset 100/200. but after booting it freezes 20210523_173540.jpg.zip
Administrators MaLd0n Posted May 23, 2021 Author Administrators Posted May 23, 2021 use mouse keyboard usb 1 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
clockT Posted May 24, 2021 Posted May 24, 2021 (edited) On 5/23/2021 at 7:45 PM, MaLd0n said: use mouse keyboard usb Hi Mald0n using USB keyboard and mouse on port 2.0, I always have the same image on boot. at startup I see that there are problems with the usb ports EDIt: fixed by disabling KErnel - XhciPortLimit Edited May 25, 2021 by clockT
Patrícia Machado Posted June 4, 2021 Posted June 4, 2021 (edited) I dont know why but the installation Big Sur to copy USB Installer to my HD is okay. But when I reboot and choose start from the HD I get this error and anything works any more ? somebody have this problem before? my PC is i7-8700 in mobo h370-gaming and radeon RX 560 boot-error.jpeg.zip Edited June 4, 2021 by Patrícia Machado
Administrators MaLd0n Posted June 4, 2021 Author Administrators Posted June 4, 2021 28 minutes ago, Patrícia Machado said: my PC is i7-8700 in mobo h370-gaming and radeon RX 560 use this folder and reset nvram first time https://tinyurl.com/y7puzwv9 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Patrícia Machado Posted June 4, 2021 Posted June 4, 2021 great! everything is running now! thks MaLd0n!! the solution was run reset nvram before continue the install process ? my Intel stay very hot when I am installing tools in terminal. Do you know something to disable the intel turbo boost by "default"?
Administrators MaLd0n Posted June 4, 2021 Author Administrators Posted June 4, 2021 need a good cooler -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Amanda Gutierrez G Posted July 5, 2021 Posted July 5, 2021 I finally found where i should post my "send me file" Thats is mine, its making me crazy
Lekins123 Posted August 8, 2021 Posted August 8, 2021 After the first installation on macOS CATALINA, and when my PC restart ..it kept bringing me back to same spot not continue the installation... Please any Help u can render i ll be appreciate that PC SAMSUNG Core i5 , 8gig ram 7th Generation thank you
Administrators MaLd0n Posted August 8, 2021 Author Administrators Posted August 8, 2021 https://www.olarila.com/topic/15040-opencore-vanilla-guide-2021-folder-for-chipsets-monterey-ready-desktop-and-notebook/ -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Виталий Емельянов Posted September 9, 2021 Posted September 9, 2021 Hello! Can I run igpu with 3d and other features (not in vesa 7mb) on my system? i3 10100 AsRock H510M-HVS Do you have some config for that? Thanks!
Administrators MaLd0n Posted September 10, 2021 Author Administrators Posted September 10, 2021 14 hours ago, Виталий Емельянов said: AsRock H510M-HVS serie 500 have problems with igpu(10th or 11th gen) -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Vitxuxo Posted October 12, 2021 Posted October 12, 2021 Opa, eu sou muito leigo pro hackintosh, e preciso fazer no notebook (Acer Aspire 3 a315) qual efi folders uso? Posso usar o big Sur? Uso qual, opencore ou clover? Eu fiz o clover com o catalina, atualizei o clover, so que fica preso na tela preta, na linha do +++++++++++++++, ai queria refazer tudo de novo, queria saber como.
