diamonddust Posted May 13, 2020 Posted May 13, 2020 With the latest OC Folder I get a "OCS: No Schema for HideSelf at 3 index!" and than after the picker it Panic and reboot i5 8500 | Gigabyte Z370P D3 (F15a) | Sapphire RX 570 itx | SMBIOS iMac19,1
Administrators MaLd0n Posted May 14, 2020 Author Administrators Posted May 14, 2020 3 hours ago, diamonddust said: With the latest OC Folder I get a "OCS: No Schema for HideSelf at 3 index!" and than after the picker it Panic and reboot work fine in many machines here -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
aryaone Posted May 16, 2020 Posted May 16, 2020 On 5/13/2020 at 11:38 AM, MaLd0n said: the problem is device ec or sta bug into rtc any patch that need to apply on config.plist to fix STA bug into RTC?
Administrators MaLd0n Posted May 16, 2020 Author Administrators Posted May 16, 2020 15 hours ago, aryaone said: any patch that need to apply on config.plist to fix STA bug into RTC? my folders have it -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Lennon85 Posted May 19, 2020 Posted May 19, 2020 On 2/29/2020 at 12:59 AM, Wagner Bonifacio Leite said: @MaLd0n me ajuda, tô quebrando a cabeça com maciASL, iasl no Windows, SSDTs .dsl que peguei no manual vanilla do OpenCore e nada. Não consegui entender ainda o que eu uso de parametro para patchear. Placa-mãe ASUS TUF B360M-PLUS Gaming/BR (não tem em catalogo nem acho nada dela como modelo de patch) Processador i5-9400F (encontrei um ssdtPRGen-coffee__lake.zip mas não funcionou só ele) O OpenCore boota, consigo formatar o HD, começo a instalar e nos minutos finais a maquina reboota. Estou anexando os arquivos que gerei dsdt.zip 172.2 kB · 4 downloads Amigo, obteve algum sucesso com o seu build? Uso o mesmo hardware, tenho o mesmo problema, e não encontro mais alternativas para testar... Se obteve sucesso, por favor compartilhe o caminho das pedras aqui.
Fantastic Posted May 25, 2020 Posted May 25, 2020 Hi, thanks for the effort. I haven't seen the EFI folder for 400 mobos on the "All Chipsets" page. Is it on this thread? Thanks!
Administrators MaLd0n Posted May 25, 2020 Author Administrators Posted May 25, 2020 13 minutes ago, Fantastic said: I haven't seen the EFI folder for 400 mobos on the "All Chipsets" page. same folder serie 100/200/300 1 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Fantastic Posted May 25, 2020 Posted May 25, 2020 2 hours ago, MaLd0n said: same folder serie 100/200/300 so it's again a rebranded Z370, Z390... There are maybe the mobo specific drivers to have sleep working properly. Thanks!!
Administrators MaLd0n Posted May 25, 2020 Author Administrators Posted May 25, 2020 Just now, Fantastic said: so it's again a rebranded Z370, Z390... no, but things are similar 1 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Fantastic Posted May 25, 2020 Posted May 25, 2020 2 hours ago, MaLd0n said: no, but things are similar With the 400 serie there are also quite often 2.5Gbit Ethernet controllers. Do you know if any of those have working drivers? Does any WiFi 6 driver exist? Thanks!
Administrators MaLd0n Posted May 25, 2020 Author Administrators Posted May 25, 2020 1 hour ago, Fantastic said: With the 400 serie there are also quite often 2.5Gbit Ethernet controllers. Do you know if any of those have working drivers? realtek yes by Mieze 1 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
diamonddust Posted June 1, 2020 Posted June 1, 2020 (edited) Last OC CoffeeLake folder work smoothly, only get this just before the OC picker. Edited June 1, 2020 by diamonddust i5 8500 | Gigabyte Z370P D3 (F15a) | Sapphire RX 570 itx | SMBIOS iMac19,1
Administrators MaLd0n Posted June 1, 2020 Author Administrators Posted June 1, 2020 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
diamonddust Posted June 1, 2020 Posted June 1, 2020 I did modify just the DeviceProperties and added the igpu and audio like this and in the EUFI section to match the Audio layout-id boot-args I just left verbose: -v 1 i5 8500 | Gigabyte Z370P D3 (F15a) | Sapphire RX 570 itx | SMBIOS iMac19,1
Hugo Quirino Posted October 6, 2020 Posted October 6, 2020 Boa tarde, @MaLd0n! Gostaria de instalar o Big Sur ou algum outro sistema macOS no computador da empresa por questões de produtividade... Com essas configurações, poderia me dar uma ajuda? Já tentei instalar o Catalina, porém, na parte da instalação que era necessário selecionar o HD, aparecia a seguinte mensagem... "O macOS não pode ser instalado neste computador", ou algo semelhante...
Administrators MaLd0n Posted October 6, 2020 Author Administrators Posted October 6, 2020 vc tem de usar smbios com suporte nos novos sistemas 1 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
vincerutabaga Posted October 12, 2020 Posted October 12, 2020 (edited) Hello @MaLd0n, I got the gigabyte gaming 7 last bios, under last catalina and Opencore 0.6.1 Everything work, but I am curious I got 1 ACPI error : ACPI Exception: AE_BAD_PARAMETER, Could not install PciConfig handler for Root Bridge PCI0(20160930/evrgnini-340) Then it search for a solution and found one : (IOPCIFamily) <IOPCIFamily`IOPCIConfigurator::createRoot()> pci (build 22:32:36 Aug 31 2020), flags 0x20c3080 then : RD: PMTrace found PCI host bridge PCI0->AppleACPIPCI I search, but found nothing about that, Is there a simple ACPI patch to correct this? I don't use full DSDT.aml patch, cause somtime I can't boot with thoses. Anymay I try some but this error remain. Thanks edit : I see now that I am in the wrong section of the forum....sorry Edited October 12, 2020 by vincerutabaga
Administrators MaLd0n Posted October 12, 2020 Author Administrators Posted October 12, 2020 26 minutes ago, vincerutabaga said: Hello @MaLd0n, if work good u can ignore it -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
vincerutabaga Posted October 12, 2020 Posted October 12, 2020 13 minutes ago, MaLd0n said: if work good u can ignore it Ok thx
neps4u Posted November 16, 2020 Posted November 16, 2020 Hello all hackintoshers, issue : Black Screen during boot I made Moajve usb stick and booted with it in few seconds during boot my screen goes black and nothing happens, so i choose config.plist2 in clover boot loader and this time i'm able to install mac osx . after reboot again i booted with USB and choose boot from MAC and i got black screen again, reboot and choose config.plist2 and boot from MAC work for me and i'm able to finish the installation. after finishing installation i replaced the efi folder from here reboot again and facing same issue Black Screen I Tried from both boot loader ( Clover and Opercore) but same result changes ig-platform-id 0x19120000 doesn't work. for info i'm using VGA cable tried with HDMI to VGA but not succeed My Spec- Motherboard : Gigabyte GA-H170M-DS3H, CPU : Intel i5 6400, Graphics : Intel HD 530, Lan : RTL 8168/8111, Audio : ALC 887
