Hackintosh Guide - Catalina / Big Sur / Monterey on Mobos Series 100, 200, 300, 400 and 500 with OpenCore Bootloader
10 hours ago, MaLd0n said:
tutorial for copy our efi folder to efi partition
the tutorial is same
Hi sir, can you please help me patching DSDT for OpenCore?
Trying my luck with OpenCore. Thank you so much!
SEND ME.ZIP
6 hours ago, Kyaalod said:
Hi sir
24 minutes ago, Kyaalod said:
I did fresh install again using opencore due to "boot failed will sleep for 10 seconds" can i still use this patch sir? Thanks!
I applied your DSDT patch sir and my battery isn't showing even I check the "show battery percentage" it will automatically hide again.
Here are my latest Send me. and when sleeping it freeze but my mouse are normal. Thank you very much.
SEND ME NEW.zip
no idea what happens
check useful links
check useful links
Here sir. Battery pecentage,  trackpad left and right click isn't working. Thank you!
Edited Add Opencorelogs
Quote
00:000 00:000 OCCPU: TSC Adjust 0
00:004 00:004 OCCPU: Known Model Core Crystal Clock Frequency    24000000Hz
00:011 00:006 OCCPU: CPUFrequencyFromART  2592000000Hz  2592MHz = 24000000 * 216 / 2
00:017 00:006 Starting ApfsDriverLoader ver. 2.1.6
00:065 00:048 EfiBootRecord located at: 9012075 block
00:073 00:007 Real image size: 629560
00:090 00:017 Signature verified!
05:068 04:761 OC: Prelink injection VoodooI2C.kext () - Invalid Parameter
05:174 00:105 OC: Prelink injection VoodooI2CHID.kext () - Invalid Parameter
SEND ME.ZIP
Edited by Kyaalod
Add opencorelogs
Buenos días,
Acabo de instalar High Sierra 2020. El problema que tengo es que no puedo actualizar USBInjectAll de la versión 0.7.1 a la 0.7.5. El error es: Kext with invalid signatured (-67050). Como lo puedo solucionar ?
Saludos y gracias.
não precisa atualizar, a usbinjectall das imagens tem todos os smbios adicionados, inclusive o macpro7,1
Buenos días
Cuando el ordenador entra en reposo y quiero activarlo tocando el mouse o el teclado se reinicia. Probé muchas cosas, como darkwake, y nada funciona. Alguna solución?
Saludos y gracias.
Solucionado con boot: slide=0 y emuvariableuefi.efi.
Edited by TBR
3 hours ago, aryaone said:
hi @MaLd0n
inject device ec or use rename
i have tried rename ECDV (my pnp0c09) to EC on config.plist, and also use SSDT-EC.aml on ACPI. but still get this strange freeze
the verbose is freeze in the middle of a word, it's not like the usual stuck on verbose
u try my last opencore folder?
4 minutes ago, aryaone said:
any suggestion @MaLd0n?
no idea
1 hour ago, aryaone said:
okay, i will wait for the update EFI Opencore from you, hope that will fix my problem
the problem is device ec or sta bug into rtc
