Hackintosh Guide - Catalina / Big Sur / Monterey on Mobos Series 100, 200, 300, 400 and 500 with OpenCore Bootloader
2 hours ago, diamonddust said:
glitchy.
check options erp
@MaLd0neu instalei o macOS Catalina no pendrive (pelo meu macbook pro, usando o DIskmaker X 9), usei o Clover_v2.5k_r5104.pkg para criar a partição EFI e o boot, copiei a pasta EFI do primeiro post (openCore 100,200,300), coloquei o arquivo gerado pela minha máquina (DSDT.aml) em ACPI/origin/, gerei os arquivos patched e tentei instalar no meu computador. Em 2 minutos para acabar a máquina trava. Atualizei o OpenCore para a ultima versão e mesmo assim dá o mesmo erro.
To te enviando o EFI final, atualizado pro 0.5.5 e com os arquivos na pasta ACPI.
Configuração do computador:
Placa-mãe: Asus TUF B360B Gaming BR
Processador: i5 9600F
Placa de vídeo: RX 580
16GB RAM
SSD 240GB exclusivo para o Hackintosh.
Agradeço desde já a ajuda.
EFI.zip
tem de patchear o dsdt
I'm having the following configuration,
ASRock Z170 itx/ac
i7-6600k
AMD RX 570
Intel NVMe SSD 660p
Default clover boot loader was working fine, when I try to use OpenCore on my system, it didn't manage to boot up.
When I unzip the EFI folder and startup, I get the attached screen and the system hangs. Therefore unable to run the RunMe app.
Thanks in advance!
IMG_0023.HEIC.zip
Edited by SriRuleZ
use ssdt olarila
https://www.olarila.com/applications/core/interface/file/attachment.php?id=24559
Hi @MaLd0n I just did a recent bios update on my Z370 board to support a 9th gen processor if I decide to get one in the future. With this update I would need to have a new DSDT made for my OpenCore system configuration if you have the time to check out my files. Thanks again for all that you do for this great community!
Send_Me Files: http://s000.tinyupload.com/?file_id=00176311356589656644
CPU: i7 8700K OC to 5Ghz
GPU: NVIDIA GTX 1080Ti
MOBO:Gigabyte Z370 Gaming 7
64 GB Corsair  Vengeance LPX Ram
the dsdt edited by you for clover with catalina but put in acpi open core does not work, Runme app does not work does not end extract I also attach the config I use. you can check and correct my problems, thanks
Archivio.zip
Edited by vrondena
dell xps13 9360
core i7
Intel HD620
-ram 8 gb ddr3
-hard disk da 256 gb SDD
On 2/23/2020 at 12:08 AM, Wagner Bonifacio Leite said:
Como faço isso?
@MaLd0n me ajuda, tô quebrando a cabeça com maciASL, iasl no Windows, SSDTs .dsl que peguei no manual vanilla do OpenCore e nada. Não consegui entender ainda o que eu uso de parametro para patchear.
Placa-mãe ASUS TUF B360M-PLUS Gaming/BR (não tem em catalogo nem acho nada dela como modelo de patch)
Processador i5-9400F (encontrei um ssdtPRGen-coffee__lake.zip mas não funcionou só ele)
O OpenCore boota, consigo formatar o HD, começo a instalar e nos minutos finais a maquina reboota.
Estou anexando os arquivos que gerei
dsdt.zip
pra que usar opencore pra instalar, use o clover que é um bootloader sólido, use o opencore  no ssd depois da install
Hey Mald0n, I tried the codeccommander.kext with SSDT-ALC1220.aml as config but still have distorted/stutter audio after wake up, It affect both the the alc1220 and the Fiio e10 USB DAC, I thought about USB map error but I re did it and still the same.
Hope you can shed some light  ;-)
diamonddust.zip
i5 8500 | Gigabyte Z370P D3 (F15a) | Sapphire RX 570 itx | SMBIOS iMac19,1
6 minutes ago, diamonddust said:
Hey Mald0n
try other layout-id, u have many options with AppleAlc
the thing is that even if I disable Audio in Bios and remove AppleALC.kext and use only USB DAC I still get distorted/stutter Audio after wake up
this card is native or use manufacturer driver?
9 minutes ago, diamonddust said:
native, one think that I notice is ioreg errors on USB where the Keyboard is connected
check logs for it, not ioreg
Quote
log show --last boot --style syslog
